Subject: Re: EPICS support for 2-D detectors/cameras
To: Mark Rivers <[email protected]>, [email protected], [email protected]
Date: Thu, 06 Mar 2008 22:42:18 -0600
Mark,
I've had thoughts of redesigning my Image Server for several years now. The software is actually capable of handling most of the disadvantages you list, however, it fails miserably in many other areas :( The biggest disadvantage is certainly the reliance on a windows only widget toolkit but there are a growing number of limitations centered on the growing use of machine vision type cameras and very high frame rates.
I've thought about the standard EPICS IOC route. The Image Server was always an application first and a PV server second. I still believe there is value in that philosophy but can see the value in going standard EPICS.
I don't see a danger in sticking with the Portable Channel Access Server. There's enough code reliant on it now that I don't see it going away. It does not suffer from the 16K barrier if built to avoid it but I generally disagree with EPICS as a means to move image data. I've already done a small amount of preliminary work in developing a new code base using the PCAS but it's nothing that can't be thrown away.
An interesting option would be the JavaIOC. My real fear there is longevity. If something happens to Marty (and I certainly hope nothing every does!) and no other facility picks it up, then the JavaIOC dies or you become daddy. Neither is appealing to me. Still, it is a tempting option and if I had time to play I might give it a try.
The rough design I was thinking about is
1) A core acquisition driver that is common for all detectors.
2) Camera drivers for each camera type. This would be very similar to the driver already in the Image Server but better abstracted from the core code than the Image Server manages. This would be the only code one would need to write to add a new detector. This part has worked very well in the Image Server and does wrapper vendor interfaces well--including vendor GUIs.
3) ROI drivers for various ROI types. This would actually be a list of drivers to support multiple ROIs. Different ROIs would be capable of different calculations, may be different shapes (some people use calculations of the ROI as point detectors at times), etc...
4) Communication drivers for communicating with the outside world. These would include EPICS and various file formats and others oddities. This would also be a list of drivers--mostly so data could be forked to multiple locations (a local USB drive for archival and also to a remote processing cluster for real time analysis, etc) There would be two main types of communication drivers: synchronous and asynchronous. Synchronous drivers would handshake with the acquisition driver to ensure data integrity. Asynchronous drivers would be allowed to drop data to allow the acquisition loop to run full tilt.
The core acquisition driver, camera and ROI drivers would register with the communication driver to provide access to the application. The GUI would be fully decoupled allowing the application to run cross platform and the GUI to be determined by the user. A "standard" GUI would be developed. I thought about ImageJ. I've written several plugins for ImageJ and there are loads of plugins available to do just about anything. It's really not the best platform for anything performance oriented (it might be difficult to use to focus the detector, for instance) but a lot features are already there.
Another key feature is that each driver would be allowed to register it's own set of fields with the communication drivers. This means each instance might have a different set of supported PVs. This has become a big issue with the Image Server and one of the motivations for a rewrite. The Image Server started with the "one set of PVs fits all" approach and its failed. To continue to maintain a full set of PVs for every camera even if they aren't used is trouoblesome and confusing to the user. The core PVs can be the same for all cameras, but does every camera need to support "Pixel Clock", "Black balance", "Frame Rate" and "White Balance". It hasn't been too combersome to provide a "camera type" PV and let the control script sort it out. The differences are almost universally in the configuration stage.
In addition to the detectors Mark lists, a new solution would need to support:
1) Cooke SensiCam
2) Sarnoff Camera
3) Detector Pool developed systems (Gold, Mercury)
4) Coreco Frame Grabber--this is a bit more complicated. The frame grabber uses a standard API for all cameras (LVDS and CameraLink mostly) but only provides an RS-232 connection for camera control. Each camera implements it's own configuration control via firmware (camera commands are rarely ever the same--even from the same manufacturer)
5) uEye USB Camera
6) Apogee cameras
7) Fairchild camera
8) And I've found it very useful to have a software generated test pattern
The Image Server also supports a few additional cameras, but I am not aware these systems are still in use and likely this support can be dropped.
9) MicroImager from QSystems--now owned by Pi/Acton (Roper)
10) Andor Technologies
11) Epix frame grabber
12) Twain (already dropped)
Plus I am aware of 2-3 potential new detector systems not covered by the above that users are considering purchasing within the next year.
I haven't walked too far down this road yet (a hesitant step or two) because I don't think it should be my decision. I've raised the issue several times (Mark and some others may remember a meeting a few years ago where Mark, Steve Shoaf and I each presented our approaches to area detectors) but things have been stable and thus no reason to do anything different. I agree with Mark that it would be nice to have a single solution for areas detectors and the community should speak up for what they need.
Brian
Re: EPICS support for 2-D detectors/cameras Kate Feng
EPICS support for 2-D detectors/cameras Mark Rivers
Prev: Re: EDM: x-y graph questions Maren Purves
Next: Software Systems Engineer position at Diamond Light Source Lizzie McCoy
Prev: Re: EPICS support for 2-D detectors/cameras D. Peter Siddons
Next: Re: EPICS support for 2-D detectors/cameras Kate Feng
