Subject: Re: EDM: x-y graph questions
To: Emmanuel Mayssat <[email protected]>
Cc: David Dudley <[email protected]>, [email protected]
Date: Thu, 06 Mar 2008 16:03:47 -1000
there's something like a strip chart in edd/dm
(but I don't know much about it, we use it on the telescope
side of things here and I'm on the instrument side).
Maren
Emmanuel Mayssat wrote:
David,
Are you talking about scrolling waveforms?
If so, as far as I know it is not possible with medm either.
The way I solve this is with FIFO records, a.k.a. compress records.
This solution should work with edm as well.
Emmanuel
On Thu, 2008-03-06 at 14:34 -0600, David Dudley wrote:
Is it possible to create a sliding y-graph in EDM?
Whatever I do, the display collects the number of samples I have
indicated, and then stops.  I need time-based scrolling graphs for a
display I'm doing (I need to display 3 or 4 of them on the page).
David
EDM: x-y graph questions David Dudley
Re: EDM: x-y graph questions Emmanuel Mayssat
Prev: Re: MEDM - EGU? Steve Lewis
Next: Re: EPICS support for 2-D detectors/cameras tieman
Prev: Re: EDM: x-y graph questions Emmanuel Mayssat
Next: Re: EDM: x-y graph questions Emmanuel Mayssat
