Subject: Re: MEDM - EGU?
Cc: [email protected]
Date: Thu, 6 Mar 2008 17:10:05 -0800
At 5:54 PM -0600 2008/03/06, Andrew Johnson wrote:
Ben Franksen wrote:
On Mittwoch, 5. März 2008, Eric Norum wrote:
You need one text-display widget for the value and a second text-
display value for the units.   You then associate the PV value field
(somePvName.VAL, or just somePvName) with the first and the PV EGU
field (somePvName.EGU) with the second.
(which I always found strange, since CA readily supports units e.g. with DBR_GR_xxx requests)
I agree, very strange. EDD/DM had a text widget that included the units as well as the value in what it displayed. Does EDM have such a thing?
The 'default' choice button on most of the TextUpdate and similar widgets in fact appends .EGU to most fields in any record (even though it usually only applies to .VAL and maybe .HOPR, .LOPR, etc)
MEDM - EGU? Heinrich du Toit
Re: MEDM - EGU? Eric Norum
Re: MEDM - EGU? Ben Franksen
Re: MEDM - EGU? Andrew Johnson
Prev: RE: MEDM - EGU? Rarback, Harvey
Next: Re: EDM: x-y graph questions Maren Purves
Next: EPICS support for 2-D detectors/cameras Mark Rivers
