Hello Heinrich,
Are you running Linux on your arm? Certain arm processors store the 8 byte
IEEE floating point values in middle endian format. If you have the latest
EPICS base I seem to recall that, on Linux, the configuration for
EPICS_FLOAT_WORD_ORDER comes from sys/parm.h and that you need not do any
special to get it to work (unless we have it coded wrong :). The relevant
code is in libCom/osi/default/osdWireFormat.h.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Heinrich du Toit
> Sent: Thursday, February 28, 2008 8:52 AM
> To: EPICS Techtalk
> Subject: floating point problem in CA?
> Hi
> This is weird and I'm not really sure how to track it down.
> I have an embedded ARM board. I've compiled EPICS onto that.
> I run vlinac (just to get something ) on my host PC (x86)
> Then I take an ai variable. (in other words a floating point thing)
> If I say from the ARM board caput pvname value
> Then the correct value gets into the pv on my host pc.
> But.. the wrong value gets back via channel access.
> if I caget the value I get the wrong answer.
> It seems that the network byte order is done wrongly maybe.. I'm not sure.
> If I put 1.0
> and then get again I get: 5.29981e-315
> Which is almost like the wrong network byte order but not exactly it
seems.
> It could be that somewhere along the lines something thinks double is 6
> bytes only (rather than 8) and then also swaps the byte order.
> Maybe there is an htons or something missing somewhere in the code?
> But how this is possible baffles me. :/
> I've written a small program to test the structure and layout off
> "double" on both my PC and the ARM. it seems identical to me.
> If anybody has any idea how I can "check" this or try and find the
> problem it would be help full.
> I am aware that the problem is not necessarily in epics but could be in
> the compiler options or something like that.
> thanks
> -Heinrich
- floating point problem in CA? Heinrich du Toit
RE: floating point problem in CA? Glen Wright
FW: floating point problem in CA? Jeff Hill
<2008>
Re: floating point problem in CA? Heinrich du Toit
<2008>
