Thanks to all for clarification!
I could build 3.14.9 with free version of MS Visual Studio 2008 Express
Edition. However, it doesn't have MFC support, which I need.
MFC in MS Visual Studio 2008 Professional Edition uses some kernel32.dll
function which doesn't exist for Windows 2000, which my users have.
Finally, MS Visual Studio 2005 Professional Edition did the job both for
EPICS build and my MFC application. (with no forgetting about the
manifest files for deployment :)).
Evgeniy
Mark Rivers wrote:
Here's from the Wikipedia article on Visual C++
Visual C++ 6.0, (commonly known as VC6) which included MFC 6.0, was
released in 1998. The release was somewhat controversial since it did
not include an expected update to MFC. Visual C++ 6.0 is still quite
popular and often used to maintain legacy projects. There are however
issues with this version under Windows XP, especially under the
debugging mode (ex: the values of static variables do not display). The
debugging issues can be solved with a patch called the "Visual C++ 6.0
Processor Pack" downloadable from
http://msdn2.microsoft.com/en-us/vstudio/aa718349.aspx; curiously, this
page stresses that Users must also be running Windows 98, Windows NT
4.0, or Windows 2000., though these requirements probably are the
minimum, which means that any computer with these version of Windows or
later will run the patch.
Visual C++ .NET 2002 (known also as Visual C++ 7.0), which included MFC
7.0, was released in 2002 with support for link time code generation and
debugging runtime checks, .NET 1.0 and Visual C# and managed C++
extensions for .NET. The new user interface used many of the hot keys
and conventions of Visual Basic, which accounted from some of its
unpopularity among C++ developers.
Visual C++ .NET 2003 (known also as Visual C++ 7.1), which included MFC
7.1, was released in 2003 along with .NET 1.1 and was a major upgrade to
Visual C++ .NET 2002. It was considered a patch to Visual C++ .NET 2002
and shipped for minimal cost to owners of that version. This is the last
version to support Windows 95 as a target.
eMbedded Visual C++ was used to develop for the Windows CE operating
system. eMbedded Visual C++ was replaced as a separate development
environment by Microsoft Visual Studio 2005.
Visual C++ 2005 (known also as Visual C++ 8.0), which included MFC 8.0,
was released in November 2005. This version supports .NET 2.0 and
dropped managed C++ for C++/CLI. It also introduced OpenMP. With Visual
C++ 2005, Microsoft also introduced Team Foundation Server. Visual C++
8.0 has problems compiling MFC Appwizard projects that were created
using Visual Studio 6.0 so maintenance of legacy projects can be
continued with the original IDE if rewriting was not feasible.
Visual C++ 2008 (known also as Visual C++ 9.0), was released in November
2007. This version supports .NET 3.5, and it is currently the latest
stable release.
I am compiling EPICS 3.14.8.2 on Visual C++ .NET 2003 (VC++ 7.1) with no
problems.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Jeff Hill
Sent: Thursday, January 31, 2008 4:31 PM
To: 'Evgeniy Tikhomolov'; [email protected]
Subject: RE: Building EPICS base 3.14.9 on Windows
Initial indications are that this compiler behavior points to
a compiler
bug. I am not, for example, experiencing that problem with
Microsoft Visual
Studio 2005 Version 8.0.50727.867, nor with sun pro, and also
not with any
version of the GNU compiler that I have tried. Your 7.0
version originates
in 2002, is probably three major releases behind the current
version. If
possible please try a more recent release from Microsoft. I
have not yet
tried Microsoft Visual Studio 2008 BTW.
If this behavior WRT MS Visual C++ 7.0 changed in a point
release that is
certainly an unfortunate result, but at this point in time it
is probably
preferable for you to move up to a more standards compliant
compiler rather
than risk introducing new code as a workaround into a mature release.
Jeff
On Behalf Of Evgeniy Tikhomolov
Sent: Thursday, January 31, 2008 1:53 PM
To: [email protected]
Subject: Building EPICS base 3.14.9 on Windows
I can't build EPICS base 3.14.9 on Windows using MS Visual C++ .NET
compiler 7.0
HOST_ARCH=WIN32
Error message:
make[3]: Entering directory
`/cygdrive/w/Epics/base-3.14.9/src/ca/O.win32-x86'
cl /nologo /EHsc /GR -c /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0 /Ox /GL /W3 /w44355
/MD -I. -I.. -I..\\..\\..\\include\\os\\WIN32
-I..\\..\\..\\include /Tp ..\\casw.cpp
casw.cpp
..\..\..\include\osiWireFormat.h(72) : error C2146: syntax error :
missing ',' before identifier 'T'
..\..\..\include\osiWireFormat.h(72) : error C2065: 'T' : undeclared
identifier
..\..\..\include\osiWireFormat.h(72) : error C2687: cannot define a
nested UDT of a template class out of line
..\..\..\include\osiWireFormat.h(72) : fatal error C1903: unable to
recover from previous error(s); stopping compilation
make[3]: Leaving directory
make[2]: Leaving directory `/cygdrive/w/Epics/base-3.14.9/src/ca'
make[1]: Leaving directory `/cygdrive/w/Epics/base-3.14.9/src'
make: Leaving directory `/cygdrive/w/Epics/base-3.14.9'
Evgeniy Tikhomolov
TRIUMF
- RE: Building EPICS base 3.14.9 on Windows Mark Rivers
Problems with edm-1.11.1 on Linux (and OS X) Eric Norum
Re: Minor VLinac compilation problem on OS X 10.5? Eric Norum
<2008>
Controls Hardware Team Leader Position at SNS White, Karen S.
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
