213> diff -u setup.sh setupLinux.sh --- setup.sh 2003-09-04 17:19:08.000000000 -0500 +++ setupLinux.sh 2008-02-26 14:56:09.181495000 -0600 @@ -50,7 +50,7 @@ export EDMOBJECTS=$EDMBASE/setup export EDMPVOBJECTS=$EDMBASE/setup -for libdir in baselib imagelib lib pvlib util choiceButton +for libdir in baselib pnglib giflib lib pvlib util choiceButton do LD_LIBRARY_PATH=$EDMBASE/$libdir/O.$ODIR:$LD_LIBRARY_PATH done @@ -74,7 +74,8 @@ echo "" else $EDM -add $EDMBASE/baselib/O.$ODIR/libEdmBase.so - $EDM -add $EDMBASE/imagelib/O.$ODIR/lib605432d2- f29d-11d2-973b-00104b8742df.so + $EDM -add $EDMBASE/pnglib/O.$ODIR/lib57d79238-2924-420b-ba67- dfbecdf03fcd.so + $EDM -add $EDMBASE/giflib/O.$ODIR/libcf322683-513e-4570- a44b-7cdd7cae0de5.so $EDM -add $EDMBASE/choiceButton/O.$ODIR/ lib7e1b4e6f-239d-4650-95e6-a040d41ba633.so $EDM -add $EDMBASE/pvFactory/O.$ODIR/libPV.so fi When I run this on Linux I get nothing but white boxes for each widget associated with a PV. When I click to bring up a 'related display' I get a segmentation fault with the following stack trace: Program terminated with signal 11, Segmentation fault. #0 ProcessVariable::add_value_callback (this=0x91e6c70, func=0x150ae0 <activeRectangleClass::visPvValueCallback(ProcessVariable*, void*)>, userarg=0x917e5a8) at ../dl_list.h:132 132 node->prev->next = node; (gdb) where #0 ProcessVariable::add_value_callback (this=0x91e6c70, func=0x150ae0 <activeRectangleClass::visPvValueCallback(ProcessVariable*, void*)>, userarg=0x917e5a8) at ../dl_list.h:132 #1 0x0014db20 in activeRectangleClass::activate (this=0x917e5a8, pass=2, ptr=0x917e588) at ../rectangle_obj.cc:1301 #2 0x002d3fc2 in activeGraphicClass::activate (this=0x917e5a8, pass=2, ptr=0x917e588, numSubObjects=0xbfcf6718) at ../act_grf.cc:1841 #3 0x002bd7d4 in activeWindowClass::execute (this=0x914ffd8) at ../act_win.cc:15837 #4 0x0029f0e5 in appContextClass::applicationLoop (this=0x9013d48) at ../app_pkg.cc:5406 #5 0x0804c2a5 in main (argc=2, argv=0xbfcf7f64) at ../main.cc:2108 When I run this on OS X I get the same white boxes, but I can bring up a related display (on which I have nothing but white boxes where PV displays/controls should be) but when I click the 'dismiss' button on the related display I get a segmentation fault. Any suggestions? This has really got us stuck. -- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
