Subject: Re: TTL output with soft IOC on Linux
To: "Emmanuel Mayssat" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 22 Feb 2008 13:40:57 -0600
Thanks, Emmanuel.
Running EPICS on Linux is not the problem.  I have been doing that for
a few years.
We have a relatively large number (~ 100) of FEE cards that only takes
on and off via TTL.  All what it does is turn on or off the FEE card.
So, using the parallel port probably will not work.
I guess I am looking for if anybody is controlling any devices via TTL
using a PCI card in Linux using EPICS.  If so, I would like to know
which TTL interface card and exactly how you are doing that.
On Fri, Feb 22, 2008 at 11:53 AM, Emmanuel Mayssat
<[email protected]> wrote:
> Jiro,
>  I use EPICS on Linux. I am not sure what a simple TTL device is.
>  If it is a PCI/PXI card look at comedi.org.
>  BTW, with comedi you can even turn your parallel port into a binary I/O
>  port. If you need more help, contact me directly.
>  Emmanuel
>  650/793-0626
>  On Wed, 2008-02-20 at 08:53 -0600, Jiro Fujita wrote:
>  > Has anybody worked with a simple TTL devices (on and off only) with
>  > soft IOC running on Linux??
>  > We have a number of FEE for one of the sub-systems for STAR detector
>  > at Brookhaven National Lab that we currently control via  EPICS 3.12
>  > with VME that we would like to move to soft IOC on Linux if all
>  > possible.
>  > I appreciate any informations/suggestions on this.
Re: TTL output with soft IOC on Linux Emmanuel Mayssat
TTL output with soft IOC on Linux Jiro Fujita
Prev: Re: Initialize multi-element field Tim Mooney
Next: Re: TTL output with soft IOC on Linux Emmanuel Mayssat
Prev: Re: TTL output with soft IOC on Linux Emmanuel Mayssat
