Subject: RE: medm weirdness
To: "Emmanuel Mayssat" <[email protected]>, "epics" <[email protected]>
Date: Wed, 6 Feb 2008 13:36:36 -0600
Did you mean scan rate of .1 Hz or .1 seconds?
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Emmanuel Mayssat
> Sent: Wednesday, February 06, 2008 1:06 PM
> To: epics
> Subject: medm weirdness
> Hello,
> I am using medm and have noticed something strange.
> I have a display with 32 waveforms.
> I can open related displays associated with each of those waveforms
> (like autoscaled waveform, moving average, etc.)
> I noticed that when I open or close a related display ( actually any
> display attached to same medm process), all the waveforms freeze.
> The IOC is working correctly.
> As if none of the monitors were working.
> When I open another related display, then the displays update again.
> Have you ever experienced this?
> Any idea where this could be coming from?
> I suspect the PV traffic could be an issue.
> Let's assume that I have 40 waveforms with 1200 samples each
> and a scan
> (and updating) rate of .1 Hz.
> Is medm overloaded?
> Regards,
> E
RE: medm weirdness Emmanuel Mayssat
Prev: medm weirdness Emmanuel Mayssat
Next: RE: medm weirdness Emmanuel Mayssat
