Subject: Re: asyn/stream reconnect problems
To: Mark Rivers <[email protected]>, [email protected]
Cc: [email protected]
Date: Tue, 29 Jan 2008 11:20:28 +0100
Hi Ben,
Please try to modify AsynDriverInterface.cc like this:
From lockRequest(unsigned long lockTimeout_ms) remove
    if (!lockTimeout_ms)
        if (!connectToAsynPort()) return false;
And modify lockHandler():
void AsynDriverInterface::
lockHandler()
    int connected;
    debug("AsynDriverInterface::lockHandler(%s)\n",
        clientName());
    pasynManager->blockProcessCallback(pasynUser, false);
    connected = connectToAsynPort();
    lockCallback(connected ? StreamIoSuccess : StreamIoFault);
Does this work?
Dirk
Mark Rivers wrote:
Benjamin,
I'd be interested to know if this problem is restricted to streamDevice,
or if it also happens if you use, for example, an asynRecord to talk to
the device.  Is it possible to test that, loading just an asyn record to
communicate with your device, and see if it re-connects after a power
cycle?
I have seen some behavior I don't understand with asyn autoconnect on IP
devices, and I've been meaning to work with Eric to track it down.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Benjamin Franksen
Sent: Monday, January 28, 2008 4:43 AM
To: [email protected]
Subject: asyn/stream reconnect problems
Strange things happen here:
When I turn off and on again a GPIB gateway (E5810A) controlled via soft IOC, asyn, and streamDevice, sometimes the connection is not re-established. However, it reconnects as soon as I enable or disable asyn debug messages a la
asynSetTraceMask L3 20 0x0000
Here is a transcript that illustrates what happens:
epics> asynSetTraceMask L3 20 0x0010
[now I turn power off and on again]
epics> 2008/01/28 11:11:29.645 L3 vxi11 clientCall errno Success clnt_stat 5
L3 vxiWriteAddressed _? RPC error : RPC: Timed out
2008/01/28 11:11:29.645 L3 callback
2008/01/28 11:11:29.645 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:29.645 L3 schedule queueRequest timeout
2008/01/28 11:11:29.645 L3 20 vxiWrite numchars 17
2008/01/28 11:11:29.857 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:29.937 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:29.937 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:29.937 L3 schedule queueRequest timeout
2008/01/28 11:11:29.992 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:29.992 L3 schedule queueRequest timeout
2008/01/28 11:11:39.645 PAHRP:NRVD:rdPow(2): asynError in write: L3 RPC failed
2008/01/28 11:11:39.645 PAHRP:NRVD:cmdGtl queueRequest
2008/01/28 11:11:39.645 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:39.645 L3 schedule queueRequest timeout
2008/01/28 11:11:39.645 L3 callback
2008/01/28 11:11:39.645 L3 20 vxiWrite numchars 17
2008/01/28 11:11:39.993 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:40.032 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:40.032 L3 schedule queueRequest timeout
2008/01/28 11:11:45.674 L3 vxiDestroyDevLink RPC error : RPC: Unable to send; errno = Broken pipe
2008/01/28 11:11:45.674 L3 vxiDisconnectPort : RPC: Unable to send; errno = Broken pipe
2008/01/28 11:11:47.681 L3 vxiDestroyDevLink RPC error : RPC: Unable to send; errno = Broken pipe
L3 port not connected
2008/01/28 11:11:47.681 L3 asynGpib:pollAddr srqEnable
2008/01/28 11:11:47.681 PAHRP:NRVD:rdPow(1): asynError in write: L3 RPC failed
2008/01/28 11:11:47.682 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:47.682 L3 schedule queueRequest timeout
2008/01/28 11:11:50.033 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:50.033 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:50.033 L3 schedule queueRequest timeout
2008/01/28 11:11:50.038 gpib0 vxiCreateDeviceLink abort channel TCP port changed from 1002 to 1005
2008/01/28 11:11:50.096 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:50.096 L3 schedule queueRequest timeout
2008/01/28 11:11:57.681 L3 asynManager:queueTimeoutCallback
2008/01/28 11:12:00.033 L3 asynManager:queueTimeoutCallback
[The last few lines repeat endlessly; device stays INVALID/TIMEOUT; now I do:]
2008/01/28 11:17:12.557 L3 addr 20 queueRequest priority 3 not lockHolder
2008/01/28 11:17:12.557 asynManager connect queueCallback port:L3
2008/01/28 11:17:12.557 L3 addr 20 vxiConnect
epics> 2008/01/28 11:17:12.559 gpib0,20 vxiCreateDeviceLink abort channel TCP port changed from 1002 to 1005
And suddenly connection is established again.
Is this a known problem? Is there a fix?
My setup: linux-x86, epicsBase3-14-8-2, asyn4-8, streamDevice2-2
Cheers
Ben
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Re: asyn/stream reconnect problems Benjamin Franksen
RE: asyn/stream reconnect problems Mark Rivers
Prev: RE: asyn/stream reconnect problems Mark Rivers
Next: Re: asyn/stream reconnect problems Benjamin Franksen
