Subject: asyn/stream reconnect problems
To: [email protected]
Date: Mon, 28 Jan 2008 11:42:30 +0100
Strange things happen here:
When I turn off and on again a GPIB gateway (E5810A) controlled via soft
IOC, asyn, and streamDevice, sometimes the connection is not
re-established. However, it reconnects as soon as I enable or disable asyn
debug messages a la
  asynSetTraceMask L3 20 0x0000
Here is a transcript that illustrates what happens:
epics> asynSetTraceMask L3 20 0x0010
[now I turn power off and on again]
epics> 2008/01/28 11:11:29.645 L3 vxi11 clientCall errno Success clnt_stat 5
L3 vxiWriteAddressed _? RPC error : RPC: Timed out
2008/01/28 11:11:29.645 L3 callback
2008/01/28 11:11:29.645 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:29.645 L3 schedule queueRequest timeout
2008/01/28 11:11:29.645 L3 20 vxiWrite numchars 17
2008/01/28 11:11:29.857 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:29.937 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:29.937 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:29.937 L3 schedule queueRequest timeout
2008/01/28 11:11:29.992 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:29.992 L3 schedule queueRequest timeout
2008/01/28 11:11:39.645 PAHRP:NRVD:rdPow(2): asynError in write: L3 RPC
failed
2008/01/28 11:11:39.645 PAHRP:NRVD:cmdGtl queueRequest
2008/01/28 11:11:39.645 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:39.645 L3 schedule queueRequest timeout
2008/01/28 11:11:39.645 L3 callback
2008/01/28 11:11:39.645 L3 20 vxiWrite numchars 17
2008/01/28 11:11:39.993 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:40.032 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:40.032 L3 schedule queueRequest timeout
2008/01/28 11:11:45.674 L3 vxiDestroyDevLink RPC error : RPC: Unable to
send;
errno = Broken pipe
2008/01/28 11:11:45.674 L3 vxiDisconnectPort : RPC: Unable to send; errno =
Broken pipe
2008/01/28 11:11:47.681 L3 vxiDestroyDevLink RPC error : RPC: Unable to
send;
errno = Broken pipe
L3 port not connected
2008/01/28 11:11:47.681 L3 asynGpib:pollAddr srqEnable
2008/01/28 11:11:47.681 PAHRP:NRVD:rdPow(1): asynError in write: L3 RPC
failed
2008/01/28 11:11:47.682 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:47.682 L3 schedule queueRequest timeout
2008/01/28 11:11:50.033 L3 asynManager:queueTimeoutCallback
2008/01/28 11:11:50.033 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:50.033 L3 schedule queueRequest timeout
2008/01/28 11:11:50.038 gpib0 vxiCreateDeviceLink abort channel TCP port
changed from 1002 to 1005
2008/01/28 11:11:50.096 L3 addr 20 queueRequest priority 0 not lockHolder
2008/01/28 11:11:50.096 L3 schedule queueRequest timeout
2008/01/28 11:11:57.681 L3 asynManager:queueTimeoutCallback
2008/01/28 11:12:00.033 L3 asynManager:queueTimeoutCallback
[The last few lines repeat endlessly; device stays INVALID/TIMEOUT; now I
do:]
2008/01/28 11:17:12.557 L3 addr 20 queueRequest priority 3 not lockHolder
2008/01/28 11:17:12.557 asynManager connect queueCallback port:L3
2008/01/28 11:17:12.557 L3 addr 20 vxiConnect
epics> 2008/01/28 11:17:12.559 gpib0,20 vxiCreateDeviceLink abort channel
TCP
port changed from 1002 to 1005
And suddenly connection is established again.
Is this a known problem? Is there a fix?
My setup: linux-x86, epicsBase3-14-8-2, asyn4-8, streamDevice2-2
Cheers
Ben
Re: asyn/stream reconnect problems Benjamin Franksen
RE: asyn/stream reconnect problems Mark Rivers
Prev: Re: subArray / waveform problem Rodney R. Porter
Next: Re: asyn/stream reconnect problems Benjamin Franksen
