Subject: Re: subArray / waveform problem
To: "Shepherd, EL (Emma)" <[email protected]>, <[email protected]>
Date: Wed, 23 Jan 2008 16:14:19 -0600
I haven't tried using the subArray record, but have done similar
manipulations using a genSub record.
Rodney Porter
On 1/23/08 9:07 AM, "Shepherd, EL (Emma)" <[email protected]>
wrote:
> I have a waveform record with FTVL set to String, but some of the
> elements are actually floating point numbers and I would like to
> separate them all out into individual records.
> Has anyone ever tried using multiple subArray records with different
> FTVL settings for this purpose?  I've tried to do this but can't get it
> to work properly, here's my problem:
> Using the following database, I can do 'caput -a ARRAY 1 2 3 4' - no
> problem, P1=1, P2=2, P3=3 and P4=4.  If I do 'caput -a ARRAY 3 4 "any
> string" 5' - P4 does not get updated, so I get P1=3, P2=4, P3="any
> string", P4=4.  In fact it seems that any numbers appearing after the
> string element in the array do not get updated.
> Any ideas? Would you expect this to work?
> record(waveform, "ARRAY") {
>   field(NELM, "4")
>   field(FTVL, "STRING")
> record(subArray, "P1") {
>   field(FTVL, "FLOAT")
>   field(INP, "ARRAY CP")
>   field(NELM, "1")
>   field(MALM, "4")
>   field(INDX, "0")
> record(subArray, "P2") {
>   field(NELM, "1")
>   field(MALM, "4")
>   field(INDX, "1")
> record(subArray, "P3") {
>   field(NELM, "1")
>   field(MALM, "4")
>   field(INDX, "2")
> record(subArray, "P4") {
>   field(NELM, "1")
>   field(MALM, "4")
>   field(INDX, "3")
> Thanks,
> Emma
> <DIV><FONT size="1" color="gray">This e-mail and any attachments may contain
> confidential, copyright and or privileged material, and are for the use of the
> intended addressee only. If you are not the intended addressee or an
> authorised recipient of the addressee please notify us of receipt by returning
> the e-mail and do not use, copy, retain, distribute or disclose the
> information in or attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual and not
> necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments
> are free from viruses and we cannot accept liability for any damage which you
> may sustain as a result of software viruses which may be transmitted in or
> with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England and
> Wales with its registered office at Diamond House, Harwell Science and
> Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
> </FONT></DIV>
subArray / waveform problem Shepherd, EL (Emma)
Prev: RE: asynRecord immutable fields Mark Rivers
Next: asyn/stream reconnect problems Benjamin Franksen
Prev: subArray / waveform problem Shepherd, EL (Emma)
