Subject: subArray / waveform problem
To: <[email protected]>
Date: Wed, 23 Jan 2008 15:07:48 -0000
I have a waveform record with FTVL set to String, but some of the
elements are actually floating point numbers and I would like to
separate them all out into individual records.
Has anyone ever tried using multiple subArray records with different
FTVL settings for this purpose?  I've tried to do this but can't get it
to work properly, here's my problem:
Using the following database, I can do 'caput -a ARRAY 1 2 3 4' - no
problem, P1=1, P2=2, P3=3 and P4=4.  If I do 'caput -a ARRAY 3 4 "any
string" 5' - P4 does not get updated, so I get P1=3, P2=4, P3="any
string", P4=4.  In fact it seems that any numbers appearing after the
string element in the array do not get updated.
Any ideas? Would you expect this to work?
record(waveform, "ARRAY") {
  field(NELM, "4")
  field(FTVL, "STRING")
record(subArray, "P1") {
  field(FTVL, "FLOAT")
  field(INP, "ARRAY CP")
  field(NELM, "1")
  field(MALM, "4")
  field(INDX, "0")
record(subArray, "P2") {
  field(NELM, "1")
  field(MALM, "4")
  field(INDX, "1")
record(subArray, "P3") {
  field(NELM, "1")
  field(MALM, "4")
  field(INDX, "2")
record(subArray, "P4") {
  field(NELM, "1")
  field(MALM, "4")
  field(INDX, "3")
Emma
<DIV><FONT size="1" color="gray">This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
</FONT></DIV>
Re: subArray / waveform problem Rodney R. Porter
Prev: Re: CA connection management - vxWorks David Maden
Next: Re: VME Toaster - has anyone else experienced this? Kurt Goetze
Prev: RE: asynRecord immutable fields Mark Rivers
Next: Re: subArray / waveform problem Rodney R. Porter
