Andrew Johnson wrote:
Owens, PH (Peter) wrote:
-----Original Message-----
From: Victor F E Pucknell [mailto:[email protected]]
Here is a simple test using the EPICS caget
Normally it is in a loop using caget every 2 seconds.
If you "quit" the EPICS server then I get a serious failure and the
test program is lost somewhere in the ca library
Please delete the "goto START" line from inside the for() loop and try
again; the program should not be recreating its CA context just because
a channel has disconnected. The CA client library handles disconnection
and reconnections itself internally, and by recreating the context every
time there's a timeout error you're almost certainly confusing it.
Also, I would think if you do this too many times you're going to get
too many connections and your IOC will become unresponsive to the
outside world (part of this quite possibly being caused by memory
fragmentation. We have one IOC that does that on occasion.).
Maren, UKIRT.
- CA connection management problem Owens, PH (Peter)
- Re: CA connection management problem Andrew Johnson
RE: CA connection management problem Jeff Hill
Re: erro when writing to the GPIB device on softIOC Stefan Heim
<2008>
RE: CA connection management problem Owens, PH (Peter)
<2008>
