Subject: Re: libgpib: IBOPENDEV ioctl failed
To: zhangdemin99 <[email protected]>
Cc: [email protected]
Date: Fri, 11 Jan 2008 09:55:39 -0800
On Fri, 2008-01-11 at 18:18 +0800, zhangdemin99 wrote:
> Dear all,
>  I am trying to communicate the gpib device with asyn.when running
> application,there is no error.
Are you saying you can start the ioc without it crashing?
Or are you saying that you can communicate with the device if you do not
use the dbpf function?
> But when I use the command dpf,it says:
> epics> dbl
> PSM6003:PSM6003Record:current
> PSM6003:PSM6003Record:current-step
> epics> dbpf PSM6003:PSM6003Record:current-step 0.5
> DBR_STRING:          0.5
> epics> libgpib: IBOPENDEV ioctl failed
> libgpib: ibfind failed to get descriptor
> 2008/01/11 15:30:20.803 L0 addr -1 : EDVR 0: OS error.
> 2008/01/11 15:30:20.804  151042680 autoConnect could not connect
Check iberr error codes
http://linux-gpib.sourceforge.net/doc_html/r530.html
You problem seems to be at the OS level.
Do you have read/write rights on the /dev/gpib* files?
> The gpib_config file is:
> interface {
>         minor = 0
>         board_type = "ni_pci"
>         name = "L0"
>         pad = 0
>         sad = 0
>         timeout = T3s
>         eos = 0x0a
>         set-reos = yes
>         set-bin = no
>         set-xeos = no
>         set-eot = yes
>         base = 0x310
>         irq  = 7
>         dma  = 0
>         master = yes
Try a stripped down version of your configuration file like the one
below. Where did you get your irq/base/dma settings? You probably don't
need them anyway.
interface {
        minor = 0               /* interface config for /dev/gpib0 */
        board_type = "ni_pci"   /* type of interface board being used */
        name = "L0"             /* optional name, allows you to get a
board descriptor using ibfind() */
        pad = 0                 /* primary address of interface */
        eos = 0x0a              /* end of string is line-feed */
        set-eot = yes           /* send EOI at end of writes */
        timeout = T3s           /* timeout for commands */
        master = yes            /* board is system controller */
Cheers,
E
libgpib: IBOPENDEV ioctl failed zhangdemin99
Prev: libgpib: IBOPENDEV ioctl failed zhangdemin99
Next: Re: VXI11 GPIB and asynRecord Eric Williams
Next: erro when writing to the GPIB device on softIOC zhangdemin99
