Dear all,
I am trying to communicate the gpib device with asyn.when running application,there is no error. But when I use the command dpf,it says: epics> dbl PSM6003:PSM6003Record:current PSM6003:PSM6003Record:current-step epics> dbpf PSM6003:PSM6003Record:current-step 0.5 DBR_STRING: 0.5 epics> libgpib: IBOPENDEV ioctl failed libgpib: ibfind failed to get descriptor 2008/01/11 15:30:20.803 L0 addr -1 : EDVR 0: OS error. 2008/01/11 15:30:20.804 151042680 autoConnect could not connect The gpib_config file is:
interface { minor = 0 board_type = "ni_pci" name = "L0" pad = 0 sad = 0 timeout = T3s eos = 0x0a set-reos = yes set-bin = no set-xeos = no set-eot = yes base = 0x310 irq = 7 dma = 0 master = yes } Have a great weekend! demin zhang 网 易 有 道 词 典 -- 全 球 最 强 大 的 免 费 英 汉 互 译 词 典 ( 只 有 2 兆 )
| ANJ, 02 Sep 2010 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
