g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013
Subject: pilatusROI R1-3 released
To: <petr.salficky@dectris.com>, "Antonino Miceli" <amiceli@aps.anl.gov>, "Beat Henrich" <beat.henrich@psi.ch>
Cc: Eric Franklin Eikenberry <eric.eikenberry@dectris.com>, beamline-controls@aps.anl.gov, bcda@aps.anl.gov, markus.naef@dectris.com, christian.broennimann@dectris.com, tech-talk@aps.anl.gov, Peter Eng <eng@cars.uchicago.edu>
Date: Tue, 8 Jan 2008 18:05:18 -0600
Folks,
I have released R1-3 of the enhanced EPICS support for the Pilatus detector.
>From the release notes:
*	Added new acquire mode, MultipleTrigger. This mode requires the firmware version that Dectris released in late 2007 (version 1215?). Multiple trigger mode takes one exposure of the programmed exposure time on each falling edge of the external trigger input signal.
*	Added new PV, ThresholdEnergy, to control the energy threshold of the Pilatus. Being able to set this value from EPICS means that there is no longer any need to run TVX, everything can be done through EPICS.
*	Added EPICS sscan records to allow the EPICS IOC to scan EPICS PVs. In particular this is very useful for scanning the ThesholdEnergy PV to make sure that it is set correctly for the energy of the x-rays in use.
*	Changed the prefix of PVs in the example IOC from GSE-PILATUS1: to PILATUS:.
*	Fixed spelling of ReadTiffTimeout in pilatusROIDoc.html.
*	Changes in the camserver protocol required the following changes:
	*	Changed all of the response numbers on expected responses (e.g.14 OK becomes 15 OK).
	*	Changed the white space in many of the expected responses.
	*	Changed the input terminator from \n\030 to \030.
*	Force NExposures (number of exposures per frame) to be 1 in all modes except External Enable.
*	Released an enhanced version of the IDL epics_image_display source code and .sav file for the IDL Virtual Machine. The new version preserves zoom and intensity scaling when new images are displayed, and adds new controls for autoscaling, zoom, and display direction. It can be obtained in the GSECARS imaging software. <http://cars.uchicago.edu/software/IDL/imaging.html>
The home page for this support is here:
http://cars.uchicago.edu/software/epics/pilatusROI.html
The detailed documentation is here:
http://cars.uchicago.edu/software/epics/pilatusROIDoc.html
Cheers,
Prev: RE: multiple levels of substitution in msi Allison, Stephanie
Next: epics functions application problem 师昊礼
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013
Prev: Soft IOC VME access Robert Ellis
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
