Leicester, PJ (Pete) wrote: A have a few gateway question:- I've never seen this message - looks to me as if the server side of the Gateway is not able to send UDP broadcasts (beacons). That would probably make it a network configuration issue of the host machine rather than a Gateway software or configuration problem. But I better leave this for Jeff to answer. 2) I notice that a '-archive' option has appeared in the latest gateway. We currently run a separate additional gateway exclusively for our archiver with the '-mask l' option to ensure we don't archive anything based on MDEL (a parallel gateway serves PV's to edm and other clients). What is the difference between '-archive' and '-mask l'? Should I now revert to having a single 'gateway -archive' for both the archiver and other (edm) clients? Would I gain/lose anything? We did make this transition recently - there should not be a noticeable functional difference. The '-mask' options sets the flags for all client connections of the Gateway, the '-archive' flag tells the Gateway to open a second client connection using the archive flag as soon as a client connects that uses the archive flag. So, '-archive' does more or less automatically what you've been doing manually so far. In both cases will regular clients get the regular (MDEL based) updates, while archiver clients will get the archive (ADEL based) events. The only difference I can see right now: With an existing regular (archive) connection, the first archiver (regular) client connecting to the same channel would issue a new name resolution broadcast on the client side and open a new tcp connection in the two-process layout, while the single process would not broadcast the name and only set up a new event subscription using the existing tcp connection (as it already is connected to the channel). 3) Where do I find a summary of the changes between gateway version 2.0.0.0 and the two later versions 2.0.2.0 and 2.0.2.1? Dirk's slides of the April 2007 EPICS meeting at DESY (ftp://ftp.desy.de/pub/EPICS/meeting-2007/ChannelAccessGatewayUpdate.pdf) should cover the main changes. Hope this helps, Ralph
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
