Hello Heinrich Maybe you can check our solution: http://www.microioc.com/loco.htm
We can measure currents in the range of 100pA - 10mA at voltages up to 10kV. You can also define interlock current value per each channel. Standard product consists of 16 modules for current measurements, but it is configurable to your applications. We also provide complete control system integration support. It is based on current to voltage to frequency converter with integration functionality that filters out noise by itself. Question that arises to me is, what is the current readout rate you require? You can contact us directly and we shall help you with this. Regards,
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
