Hello!
I've run into a problem I'm guessing others have solved using the
Streams module. I have a device that outputs reads in the format:
U1\r\n+00011-01\r\n
meaning 11e-01 , which would be the preferred format for using a
general format specifier in the protocol file.
What would be the format to successfully read in this number from the
Streams protocol file?
(Or, will I have to run as a string read through a c filter program,
sub record)
Thank you!
Eric
- Re: Streams questions Dirk Zimoch
Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
RE: Streams questions Mohan Ramanathan
<2007>
RE: building EPICS base on Mac OS X 10.5 (Leopard) Denison, PN (Peter)
<2007>
