1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem with assert in dbLock.c
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Mon, 19 Nov 2007 13:34:58 -0600
On Nov 19, 2007, at 1:26 PM, David Dudley wrote:
Got farther, but not all the way. I assume that the MessageQueueTest shouldn't take 'minutes', as none of the others took over at most about 5-10 seconds.
Not sure what the timer test failing is. It was working before, and looks like an upgrade must have killed it. Also, it isn't very consistent. I've seen it fail tests 2-5, 2-4, and 2-3 at various times. The MessageQueTest runs for quite a while, and then I killed it.
Actually the message queue test *is* supposed to run for a while. It even says so:
ok 55 - Send with no receiver
ok 56 - receive into undersized buffer returned error (-1)
# Single receiver, single sender tests:
# priority-based scheduler, sent 4 messages
# scheduler not strict priority, sent 5 messages
ok 57 - 10 of 10 messages sent with sender pauses
# Single receiver, multiple sender tests:
# This test takes 5 minutes...
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
Re: Problem with assert in dbLock.c David Dudley
Re: Problem with assert in dbLock.c Andrew Johnson
Prev: Re: Problem with assert in dbLock.c David Dudley
Next: Re: Problem with assert in dbLock.c David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
