thanks, tom I get the following result and error when running make: t6p@i73072: make make -C config install perl /Library/EPICS/Versions/Current/configure/tools/makeMakefile.pl O.darwin-x86 ../.. mkdir O.Common make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86 install make[2]: Nothing to be done for `install'. make -C configure install perl /Library/EPICS/Versions/Current/configure/tools/makeMakefile.pl O.darwin-x86 ../.. mkdir O.Common make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86 install perl /Library/EPICS/Versions/Current/configure/tools/convertRelease.pl -h darwin-x86 CONFIG_APP_INCLUDE make -C src install make -C libCom install perl /Library/EPICS/Versions/Current/configure/tools/makeMakefile.pl O.darwin-x86 ../../.. mkdir O.Common make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86 install perl ../../../src/libCom/misc/makeEpicsVersion.pl /Library/EPICS/ Versions/Current/configure/CONFIG_BASE_VERSION ../O.Common Building epicsVersion.h from /Library/EPICS/Versions/Current/configure/ CONFIG_BASE_VERSION Found EPICS Version 3.14.9 Installing generated generic include file ../../../include/ epicsVersion.h /usr/bin/cc -c -DUNIX -Ddarwin -ansi -O3 -Wall -fno-common -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../ src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/ cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/ cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib - I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/ libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/ gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib - I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/ libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Darwin -I../../../include -I/opt/local/ include -I/sw/include ../../../src/libCom/bucketLib/bucketLib.c /usr/libexec/gcc/i686-apple-darwin8/4.0.1/as: assembler (/usr/bin/../ libexec/gcc/darwin/i386/as or /usr/bin/../local/libexec/gcc/darwin/ i386/as) for architecture i386 not installed Installed assemblers are: /usr/bin/../libexec/gcc/darwin/ppc64/as for architecture ppc64 /usr/bin/../libexec/gcc/darwin/x86_64/as for architecture x86_64 make[3]: *** [bucketLib.o] Error 1 make[2]: *** [install.darwin-x86] Error 2 make[1]: *** [libCom.install] Error 2 make: *** [src.install] Error 2 t6p@i73072:
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
