Hi, Andrew.
Have you made any more progress with this? Or are you waiting on a
response from Carl to your below email from a week ago?
I'm willing to do a little testing if you have a patch you'd like
someone to try out.
-lewis
On 11/9/07 1:18 PM, Andrew Johnson wrote:
Hi Carl,
Thanks for the fixes. Should the get_array_info() function be changed
to set *no_elements to zero when psa->udf is true? Currently it is set
from psa->nelm on UDF, which looks wrong to me. Should the same apply
in cvt_dbaddr()?
If you think there should be changes in the waveform record that make it
behave more sensibly and won't break documented behavior I'd be happy to
consider them.
- Andrew
- Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
- RE: subArray INDX field set to 0 if NORD <= 0 Gillingham, IJ (Ian)
- Re: subArray INDX field set to 0 if NORD <= 0 Carl Lionberger
Re: SDDS lapack compile error Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Re: SDDS lapack compile error Janet Anderson
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
