1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS on RTEMS
To: Heinrich du Toit <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 16 Nov 2007 07:23:16 -0600
We have a number of ColdFire uCDIMM modules with 16 MB of RAM and 4.5 MB of flash.
http://www.arcturusnetworks.com/products/uc5282/
In one of the larger applications (beam position monitor) this handles about 500 PVs.
I think that 16 MB of RAM is probably as low as you'd want to go. I used to run some Motorola 68360 systems with 4 MB of RAM, but that was really limiting.
It depends somewhat on the CPU architecture, but typically an application+EPICS+RTEMS is one to two MB of code space. Here's what the aforementioned BPM IOC uses:
m68k-rtems4.7.1-size srmonopulsebpm/bin/RTEMS-uC5282/srbpm
text data bss dec hex filename
1629008 60032 105520 1794560 1b6200 srmonopulsebpm/bin/RTEMS- uC5282/srbpm
Flash -- you need only enough to do a net boot. 1M would be plenty.
On Nov 16, 2007, at 4:37 AM, Heinrich du Toit wrote:
Hi
Can somebody give me an indication of how much flash/SRAM is needed by a system on RTEMS to run EPICS?
thanks
-Heinrich
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
Re: EPICS on RTEMS Heinrich du Toit
Prev: EPICS on RTEMS Heinrich du Toit
Next: Problem solved : building device support on external library - help needed John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: EPICS on RTEMS Heinrich du Toit
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
