1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Power Supply Record?
To: [email protected]
Date: Thu, 15 Nov 2007 09:31:13 -0600
Just to add to the consensus. I also strongly recommend using templates of basic record types, rather than creating a custom record. There's very little that can't be done with the existing semantics of basic records and links (although admittedly it can take a while to learn all the tricks). For me, it became clear quickly that if I went the custom record route, I would wind up with 5 or more custom records, each of which then has to be debugged and maintained. Then, when you consider tweaks to add functionality later on, it is easier to link in a few new basic records than it is to try and integrate a tweak into the C support code of a large custom record.
regards, Claude
Susanna Jacobson wrote:
Hello folks,
Here in the Controls Group at the Advanced Light Source, we are considering writing a custom Power Supply record. If your installation has one already, would you share it with us for reference?
I would also welcome any advice or cautions you have, based on your experience in this area.
Thanks in advance,
Susanna
Anyone have Epics support for ADSC 315r CCD detector? Russ Berg
Power Supply Record? Susanna Jacobson
Prev: RE: WIENER crate Elder Matias
Next: Anyone have Epics support for ADSC 315r CCD detector? Russ Berg
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Power Supply Record? Geoff Savage
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
