[...] we are considering writing a custom Power Supply record. [...]Hi Susanna, I had a similar idea 8 years ago for some in-house developed power supply at PSI. Luckily I got some advice not to do it that way (Thanks Bob!). If you use one record per power supply, your application will suffer from a lack of expandability, flexibility and usability. Just some simple example: Expandability: My specification at the beginning consisted of about a dozen values for one power supply. Within one year this did grow by a factor of 10. I would rather have a template with 120 records connected to one power supply, then having a record with 120 fields. Flexibility: If you want to read a new value-type (e.g. resistance) from your PS, and let's say you have a serial connection to your PS. Reading the new value should be possible by just adding a few lines in your protocol file and adding an "ai" record. But if you have to add a field to a record it becomes much more trouble. Usability: you will read back a current and a voltage from the power supply. Is HOPR/LOPR the display range for the current or the voltage? Of course you can have an IHOP/ILOP and VHOP/VLOP, but since there is just one function get_graphic_double, no standard display will be able to use those fields context sensitive. The same applies to ADEL, MDEL, HIGH, HIHI, LOW, LOLO, .... Other people may disagree, but I would strongly advice you not to develop a power supply record. Good luck with your power supplies anyway ;-) Cheers Andreas -- Dr. Andreas Luedeke, SLS Operations Manager, Tel:+41-56-3104002 [email protected], http://people.web.psi.ch/luedeke
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
