Hi Eric,
Eric Norum wrote:
> Just adding the prototype is likely to just postpone the problem till
> link time (undefined symbol finite). I think that it would be better to
> use the standard routine instead:
> 1) Find all references to finite and change them to isfinite.
> 2) For systems which provide finite() rather than isfinite(), add a
> macro to <os>/epicsMath.h defining the latter as the former.
I agree. Actually, I have replaced all references to finit() in
epicsCalcTest.cpp to that to isfinite() and found it is compiled without
any error.
So your epicsMath.h for os/Darwin should work for Darwin platform.
Noboru
> On Nov 4, 2007, at 5:46 PM, Noboru Yamamoto wrote:
>> Hi,
>> On MacOSX 10.5, finite() is declared
>> extern int finite ( double ); /* Legacy API: please
>> use C99 isfinite() instead. */
>> but not
>> extern "C" int finite(double);
>> This seems causing the error shown by Biritz-san.
>> 1) replace call to finite with call to isfinite.
>> or
>> 2) add
>> in somewhere in epicsCalcTest.cpp.
>> eliminates the error message.
>> Bertrand H.J. Biritz wrote:
>>> Dear Tech-Talk,
>>> so I am one of those Mac fanboys (at least when it comes to the OS) who
>>> installed OS X 10.5 (Leopard) as soon as it came out.
>>> Naturally EPICS will not compile on it - would have been surprised if it
>>> had. I get the following error message:
>>> ../epicsCalcTest.cpp: In function 'double doCalc(const char*)':
>>> ../epicsCalcTest.cpp:31: error: 'finite' was not declared in this scope
>>> ../epicsCalcTest.cpp: In function 'void testCalc(const char*, double)':
>>> ../epicsCalcTest.cpp:51: error: 'finite' was not declared in this scope
>>> ../epicsCalcTest.cpp:55: error: 'finite' was not declared in this scope
>>> ../epicsCalcTest.cpp: In function 'int main(int, char**)':
>>> ../epicsCalcTest.cpp:170: error: 'finite' was not declared in this scope
>>> make[3]: *** [epicsCalcTest.o] Error 1
>>> make[2]: *** [install.darwin-ppc] Error 2
>>> make[1]: *** [libCom/test.install] Error 2
>>> make: *** [src.install] Error 2
>>> Did I miss something in the installation instructions?
>>> This is with base-3.14.9 on a PPC.
>>> Thanks,
>>> Bertrand
>> my environment:
>> Mac OSX10.5 running on MacBook(1st generation).
>> Xcode 3.0
>> EPICS R3.14.9 base
>> Regards,
>> Noboru
>> <noboru.yamamoto.vcf>
begin:vcard
fn:Noboru Yamamoto
n:Yamamoto;Noboru
email;internet:[email protected]
tel;work:+81-29-864-1171, ext. 5209
tel;fax:+81-29-879-6130
x-mozilla-html:FALSE
version:2.1
end:vcard
- Re: EPICS on Mac OS X 10.5 Andrew Johnson
- EPICS on Mac OS X 10.5 Bertrand H.J. Biritz
- Re: EPICS on Mac OS X 10.5 Noboru Yamamoto
- Re: EPICS on Mac OS X 10.5 Eric Norum
RE: cmlog ? (still not working) Heinrich du Toit
Qt edm code John Sinclair
<2007>
<2007>
