1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: lexical analyzer for .db?
To: Ned Arnold <[email protected]>
Cc: [email protected]
Date: Fri, 2 Nov 2007 08:53:54 -0500
On Nov 2, 2007, at 8:30 AM, Ned Arnold wrote:
You may be able to eliminate the fanout records by careful design of forward links and/or input link flags (PP, CP, etc).
For example, if the input record's forward link field referenced the calc record and the calc record's forward link field referenced the calcout record, all would process each time the input record processed ... without a fanout.
Don't take this technique to extremes, though. I recall helping Steve Shoaf diagnose problems with his database for a video switching system. The database contained 128 records FLNK'd together. This caused very weird IOC faults that we finally realized were caused by stack overflow of the task processing the records -- 128 recursive calls to the record processing routine forced the task stack pointer past the end of the stack space.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: lexical analyzer for .db? Heinrich du Toit
Re: lexical analyzer for .db? Ben Franksen
Re: lexical analyzer for .db? Andrew Johnson
Re: lexical analyzer for .db? Ned Arnold
Prev: Re: lexical analyzer for .db? Ned Arnold
Next: Re: lexical analyzer for .db? Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
