Ned Arnold wrote:
Chen -
Yes, you can change the SCAN value dynamically. Options would include:
- Place a menu widget on your EDM screen assigned to the
<fanoutRecord>.SCAN field and have the user interactively set it to the
optimum value
if you use a mbbo connected to the .SCAN field - and then use the
mbbo in your EDM screen - you can set it so that it only allows
'legal' values for the SCAN period.
HTH,
Maren
- Add a calcout record in your IOC database that calculates the
optimum value (based on your description) and write this value to
<fanoutRecord>.SCAN.
Have fun -
Ned
On Oct 31, 2007, at 8:50 AM, Zhichu Chen wrote:
Hi all,
It's an interesting story. I've written an EPICS program and gotten it
run on an oscilloscope partly successfully and used EDM to get
waveforms and set parameters through CA.
What I mean by "partly" is, I used a fanout record to get waveforms
from four channels and set it scan periodically, say "1 second," and
it works fine unless the time scale is bigger than 0.02---0.02 is fine
and 0.05 will make the oscilloscope stun until I set the time scale
back to less than 0.05.
Finally, I figure out and set the SCAN field of the fanout record to
"5 second" and it works again. So I guess, since time scale is 1/10 of
the whole waveform---whose unit is "second"---and there're four
waveforms I registered. So it will take 40*timescale to get all I want
because I've told that my product---DPO7054---used only one probe for
all four channels. Before I get the waveform, the buffer is locked and
will never refresh in my case.
I know I can set SCAN to a very big number but, when the time scale is
small, I think it's not efficient then. I'm just wondering whether I
could use another record to control it, or something alternative.
- VMIC 2534 3.14 support? Laznovsky, Michael
- Is there any chance that I can change SCAN parameter dynamically? Zhichu Chen
- Re: Is there any chance that I can change SCAN parameter dynamically? Ned Arnold
Re: Is there any chance that I can change SCAN parameter dynamically? Zhichu Chen
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
