Zhichu Chen wrote:
[...] So it will take 40*timescale to get all I want [...]
I know I can set SCAN to a very big number but, when the time scale is
small, I think it's not efficient then. I'm just wondering whether I
could use another record to control it, or something alternative.
Hi Chen,
the choices of SCAN are rather limited.
In your case I would suggest that your calculate the desired readout
period from the timescale and use a counter to process your readout. E.g.:
record(calcout,"la:s") {
field(SCAN,"1 second")
field(INPA,"la:s.VAL")
field(INPB,"la:t.VAL")
field(CALC,"A+1>=B?0:A+1")
field(OOPT,"When Zero")
field(OUT,"la:cnt.PROC")
record(longin,"la:t") {
field(INP,"1")
field(EGU,"s")
record(calc,"la:cnt") {
field(INPA,"la:cnt")
field(CALC,"A+1")
Here the record la:cnt is processed every "la:t" seconds (for "la:t">0).
Cheers
Andreas
- Re: Is there any chance that I can change SCAN parameter dynamically? Zhichu Chen
- Is there any chance that I can change SCAN parameter dynamically? Zhichu Chen
Re: Is there any chance that I can change SCAN parameter dynamically? Ned Arnold
<2007>
Re: VMIC 2534 3.14 support? Steven Hartman
<2007>
