All,
I actually see a strange behavior when I use the Raw Converter.
So far, I have been using StreamDevice in SynApps-5_2.
So now, I would like to reinstall the latest and greatest of
StreamDevice, a.k.a StreamDevice-2-3
Is there an install file hidden somewhere? I couldn't find it!
Apparently the tar.gz archive needs to be installed in epics-base, to be
able to find the configure directory. But there again, it doesn't fully
compile (iocshCmd linking error)... I am probably doing something wrong.
Where are the install instructions for StreamDevice?
Thank you,
E
On Tue, 2007-10-30 at 11:10 -0700, Emmanuel Mayssat wrote:
> Hello all,
> I am using stream and a 16 bit word to convert to an unsigned integer (0
> to 64xxx). The unsigned integer is coded on 2 characters.
> So I use the raw converter and particularly %2.2r
> But with that converter then the integer is signed (as mentioned in the
> doc). So I can read values between 0 to 32767 and -32768 to -1.
> Is there a way to use unsigned integer with the raw converter or do I
> have to write my own converter?
> Looking at the RawConverter.cc code, I am afraid that I will have to
> write my own...
> Emmanuel
- Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
- Re: Stream Raw converter and un/signed integrer Dirk Zimoch
- Stream Raw converter and un/signed integrer Emmanuel Mayssat
Re: alh not handling log files correctly Janet Anderson
<2007>
<2007>
