1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: combining values into graph?
To: Heinrich du Toit <[email protected]>, TechTalk EPICS <[email protected]>
Date: Tue, 30 Oct 2007 07:56:10 -0500 (CDT)
Heinrich -
The vlinac uses a sequence program (source is in the src directory) that monitors all of the individual BPM readings, assembles them into a convenient waveform, and writes the waveform to a "soft" waveform record for all the world to see.  A sequence program can connect to PVs in several IOCs, so this is one way to do what you want.  I suggest that it also create a second waveform to be used as the X axis (on medm) to give the plot more meaning.
Have fun -
   Ned
>Hi
>If I have say 5 scanners throught the beamline..
>And from each scanners data I calculate the centre position for both the
>vertical and horizontal scan.
>How do I combine these 5 variables (or more) variables into 2 waveforms
>or something that I can display in say MEDM on a graph.
>Something like what is done in VLinac.
>Although I can't figure out how it is done in vlinac?
>thanx
>-Heinrich
Prev: Re: GpibBoardDriverConfig not found Gasper Jansa
Next: Re: acf syntax to include other acf files Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: combining values into graph? Heinrich du Toit
Next: GpibBoardDriverConfig not found zhangdemin99
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
