Hi
Did you set LINUX_GPIB=YES in configure/RELEASE file when compiling
asynDriver?
Regards
Gasper
zhangdemin99 wrote:
Dear all,
I haved built asyn4-8,linux-gpib-3.2.09 on my linux system. when I
run the application for a GPIB device, there are some problems:
#!../../bin/linux-x86/PSM6003
##You may have to change PSM6003 to something else
##everywhere it appears in this file
<envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocPSM6003")
epicsEnvSet(TOP,"/home/zhm/software/gpib/psm6003")
epicsEnvSet(PSM6003,"/home/zhm/software/gpib/module/psm6003")
epicsEnvSet(ASYN,"/home/zhm/software/gpib/asyn")
epicsEnvSet(EPICS_BASE,"/home/zhm/software/gpib/base-3.14.9")
cd /home/zhm/software/gpib/psm6003
##Register all support components
dbLoadDatabase("dbd/PSM6003.dbd",0,0)
PSM6003_register Record Device Driver(pdbbase)
cd /home/zhm/software/gpib/asyn
##Load record instances
dbLoadRecords("db/asynRecord.db","P=PSM6003,R=Test,PORT=L0,ADDR=1,
IMAX=0,OMAX=0")
GpibBoardDriverConfig("L0",1,0,3,0)
st.cmd -- Line 17 --Command GpibBoardDriverConfig not found
cd /home/zhm/software/gpib/psm6003/iocBoot/iocPSM6003
iocInit()
Starting iocInit
##EPICS R3.14.9- $R3-14-9-pre1$ $2006/11/20 21:09:36$
##EPICS Base built Oct 29 2007
2007/10/30 14:10:11.084 PSM6003Test:Connect error,status=3,asynManager:
connectDevice port L0 not found
iocInit:All initialization complete
##Start any sequence programs
#set sncxxx ,"user=zhmHost"
The CA server's beacon address list was empty after initialization?
epics>
any help or suggestions will be most welcome. Many thanks in advance.
demin zhang
LOGO æçåæåçåïåååèèäåé
<http://popme.163.com/link/003515_0929_938.html>
åæååèçåèèåçåèå
- GpibBoardDriverConfig not found zhangdemin99
Re: combining values into graph? nda
<2007>
Re: GpibBoardDriverConfig not found zhangdemin99
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
