1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Stream device
To: "Szalata, Zenon M." <[email protected]>, "Dirk Zimoch" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 25 Oct 2007 15:03:10 -0500
(Sorry for the previous post, keyboard error)
This is strange, because you are getting the following message (which is
a known "warning" we need to fix)
> 2007/10/25 09:08:50.062 asynManager::asynConnectCallback, port L0
error calling
> asynCommon->connect L0 addr 0 vxiConnect request but already connected
So it says port LO is already connected.
But then you get this:
> 2007/10/25 09:08:50.083 AG:RFreq: asynError in write: L0 port is not
connected
Which says the port is not connected.
> -----Original Message-----
> From: Szalata, Zenon M. [mailto:[email protected]]
> Sent: Thursday, October 25, 2007 11:17 AM
> To: Mark Rivers; Dirk Zimoch
> Cc: EPICS tech-talk
> No, this did not fix the problem.  Here is what I get first
> with 1, then with 255 in the third argument...
> #!../../bin/linux-x86/atest
> < envPaths
> epicsEnvSet(ARCH,"linux-x86")
> epicsEnvSet(IOC,"iocagwfg")
> epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest")
> epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-9")
> epicsEnvSet(STRM,"/afs/slac/g/esa/ilc/epics/modules/streamdevice-2-3")
> epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
> epicsEnvSet( "STREAM_PROTOCOL_PATH","../../atestApp/Db:.")
> cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest
> ## Register all support components
> dbLoadDatabase("dbd/atest.dbd",0,0)
> atest_registerRecordDeviceDriver(pdbbase)
> vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
> asynSetTraceMask( "L0",0,1)
> dbLoadRecords("db/atest.db","P=AG:")
> cd
> /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest/iocBoot/iocagwfg
> iocInit()
> Starting iocInit
> ## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$
> ## EPICS Base built Oct  2 2007
> 2007/10/25 09:08:49.526 L0 port not connected
> port L0 error calling
> is not connected
> 2007/10/25 09:08:50.083 AG:RFreq: @init handler failed
> 2007/10/25 09:08:50.083 AG:RFreq: Record initialization failed
> 2007/10/25 09:08:50.083 AG:WFreq: asynError in write: L0 port
> is not connected
> 2007/10/25 09:08:50.084 AG:WFreq: @init handler failed
> 2007/10/25 09:08:50.084 AG:WFreq: Record initialization failed
> Bad init_rec return value  PV: AG:WFreq ao: init_record
> iocInit: All initialization complete
> epics> exit
> zms@esaux1 $
> zms@esaux1 $
> zms@esaux1 $
> zms@esaux1 $ ../../bin/linux-x86/atest st.cmd
> < envPaths
> asynSetTraceMask( "L0",0,255)
> cd
> iocInit()
> Starting iocInit
> 2007/10/25 09:09:52.303 L0 port not connected
> 2007/10/25 09:09:52.845 asynManager connect queueCallback port:L0
> 2007/10/25 09:09:52.845 L0 addr 0 vxiConnect
> 2007/10/25 09:09:52.845 asynManager::asynConnectCallback,
> 2007/10/25 09:09:52.865 AG:RFreq: asynError in write: L0 port
> is not connected
> 2007/10/25 09:09:52.865 AG:RFreq: @init handler failed
> 2007/10/25 09:09:52.865 AG:RFreq: Record initialization failed
> 2007/10/25 09:09:52.865 AG:WFreq: asynError in write: L0 port
> is not connected
> 2007/10/25 09:09:52.865 AG:WFreq: @init handler failed
> 2007/10/25 09:09:52.865 AG:WFreq: Record initialization failed
> epics> 2007/10/25 09:10:02.868 AG:RFreq: asynError in write:
> L0 port is not conn
> ected
> exit
> Thanks,
> Zen
> From: Mark Rivers [mailto:[email protected]]
> Sent: Thursday, October 25, 2007 7:49 AM
> To: Dirk Zimoch; Szalata, Zenon M.
> Cc: EPICS tech-talk
> Hi Zen,
> Please try adding the asynSetTraceMask command to your st.cmd
> right after the vxi11Configure command.
> asynSetTraceMask("LO",0,1)
> That will force a connection to the controller before
> iocInit.  See if it helps.  If it does not help then change
> the line to:
> asynSetTraceMask("LO",0,255)
> so we can get a complete printout of what is happening.
> Mark
> > From: [email protected]
> > [mailto:[email protected]] On Behalf Of Dirk Zimoch
> > Sent: Thursday, October 25, 2007 6:46 AM
> > To: Szalata, Zenon M.
> > Cc: EPICS tech-talk
> > Subject: Re: Stream device
> > Hi Zen,
> > the @init handler runs during iocInit, to be exact during
> init_record.
> > Maybe the
> > vxi11 has not yet connected by that time (when interruptAccept is
> > still 0). I have to check that. I only tested it with
> serial and TCP
> > ports so far.
> > Unfortunately, not all asyn ports behave the same.
> > I have not time this week any more. I hope I can help you
> by the end
> > of next week.
> > Dirk
> > Szalata, Zenon M. wrote:
> > > I am learning to use stream device to implement a soft IOC
> > to control an Agilent 33220A waveform generator, which is
> attached to
> > an ICS 8065 Ethernet-GPIB controller.  I have a very simple
> program at
> > this point.  It consists of two
> > records: ai and ao and a very simple protocol file.  I am unable to
> > use the @init{} command/handler.  Without the @init{} commented out
> > the program works as it should.  But when I uncomment either of the
> > two @init{} statements an error results. Here is the output:
> > > #!../../bin/linux-x86/atest < envPaths
> > > cd
> > > iocInit()
> > > Starting iocInit
> > > ## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$ ##
> EPICS Base
> > > built Oct  2 2007
> > > 2007/10/24 18:21:44.742 L0 port not connected
> > > 2007/10/24 18:21:45.307 AG:RFreq: asynError in write: L0
> > > 2007/10/24 18:21:45.308 AG:RFreq: @init handler failed
> > > 2007/10/24 18:21:45.308 AG:RFreq: Record initialization failed
> > > 2007/10/24 18:21:45.308 AG:WFreq: asynError in write: L0
> > > 2007/10/24 18:21:45.308 AG:WFreq: @init handler failed
> > > 2007/10/24 18:21:45.308 AG:WFreq: Record initialization
> failed Bad
> > > epics> exit
> > > Here is my atest.db:
> > > record( ai,"$(P)RFreq"){
> > >   field( DESC, "read frequency")
> > >   field( DTYP, "stream")
> > >   field( SCAN, "10 second")
> > >   field( PREC, "2")
> > >   field( EGU,  "Hz")
> > >   field( INP,  "@atest.proto rFreq L0 8") } record(
> ao,"$(P)WFreq"){
> > >   field( DESC, "write frequency")
> > >   field( SCAN, "Passive")
> > >   field( PREC, "2")
> > >   field( EGU,  "Hz")
> > >   field( OUT,  "@atest.proto wFreq L0 8") }
> > > And atest.proto, shown here with both @init statements
> > commented out:
> > > # file: atest.proto
> > > Terminator=LF;
> > > #@init{ out " ";}
> > > rFreq{
> > >  out "FREQ?"; in "%f";
> > > wFreq{
> > >  out "FREQ %f";
> > > # @init{ rFreq;}
> > > Also here is atestApp/src/Makefile
> > > TOP=../..
> > > include $(TOP)/configure/CONFIG
> > > #  ADD MACRO DEFINITIONS AFTER THIS LINE
> > > # build an ioc application
> > > PROD_IOC = atest
> > > DBD += atest.dbd
> > > # atest.dbd will be made up from these files:
> > > atest_DBD += base.dbd
> > > atest_DBD += atestSup.dbd
> > > atest_DBD += stream.dbd
> > > atest_DBD += asyn.dbd
> > > atest_DBD += drvVxi11.dbd
> > > # <name>_registerRecordDeviceDriver.cpp will be created
> > from <name>.dbd
> > > atest_SRCS += atest_registerRecordDeviceDriver.cpp
> > > atest_SRCS_DEFAULT += atestMain.cpp
> > > atest_SRCS_vxWorks += -nil-
> > > #The following adds support from base/src/vxWorks
> atest_OBJS_vxWorks
> > > += $(EPICS_BASE_BIN)/vxComLibrary
> > > #add a definition for each support application used by this
> > application
> > > atest_LIBS += asyn
> > > atest_LIBS += stream
> > > #atest_LIBS += genSub
> > > #atest_LIBS += calc
> > > atest_LIBS += $(EPICS_BASE_IOC_LIBS)
> > > include $(TOP)/configure/RULES
> > > #  ADD RULES AFTER THIS LINE
> > > And contents of my atestSup.dbd:
> > > registrar( drvAsynIPPortRegisterCommands)
> > > When the @init statements are commented out, this is what I get:
> > > < envPaths
> > > cd
> > > iocInit()
> > > Starting iocInit
> EPICS Base
> > > built Oct  2 2007
> > > epics> dbl
> > > AG:RFreq
> > > AG:WFreq
> > > epics>
> > > And I can examine the value read in a very simple edm screen.
> > > Sorry for such a lengthy note.  Thanks for helping, Zen
> > Dr. Dirk Zimoch
> > Paul Scherrer Institut, WBGB/006
> > 5232 Villigen PSI, Switzerland
> > Phone +41 56 310 5182
RE: Stream device Szalata, Zenon M.
Prev: RE: Stream device Mark Rivers
Next: Re: Automated logbook Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Stream device Szalata, Zenon M.
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
