1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: another question on custom record stuff
To: "Heinrich du Toit" <[email protected]>, "TechTalk EPICS" <[email protected]>
Date: Thu, 25 Oct 2007 04:51:52 -0700
The issue here is that EDM (and all other channel access clients of which I am aware) only make a get request for graphic information at connection time to limit the amount of network traffic. This has been on the list for a long time - the ability to monitor the metadata and get a dbr_graphic_double only when the metadata changes and get the value, time stamp status all other times.
What is the display limit field being used to do? I thought that all array plotting tools had scaling available through the display.
Bob
-----Original Message-----
From: [email protected] on behalf of Heinrich du Toit
Sent: Thu 10/25/2007 4:36 AM
To: TechTalk EPICS
Subject: another question on custom record stuff
I have a field that is an array
And with that field I have the get_graphic_double routine that gives out
the limits for that array.
Now I have another field that is actually the limit.
So the get_graphic_double routine simply puts that field inside
upper_disp_limit
And it work well the first time.
Now the problem is that if I change the limit field then well.
MEDM just doesn't know about it.
So how do I get that part to run again?
Or is this another one of those impossible things :(
another question on custom record stuff Heinrich du Toit
Prev: RE: unique alarms for fields? Dalesio, Leo `Bob`
Next: Epicstcl Eric Berryman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: another question on custom record stuff Heinrich du Toit
Next: RE: another question on custom record stuff Jeff Hill
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
