I am learning to use stream device to implement a soft IOC to control an Agilent 33220A waveform generator, which is attached to an ICS 8065 Ethernet-GPIB controller. I have a very simple program at this point. It consists of two records: ai and ao and a very simple protocol file. I am unable to use the @init{} command/handler. Without the @init{} commented out the program works as it should. But when I uncomment either of the two @init{} statements an error results. Here is the output:
zms@esaux1 $ ../../bin/linux-x86/atest st.cmd
#!../../bin/linux-x86/atest
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocagwfg")
epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest")
epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-9")
epicsEnvSet(STRM,"/afs/slac/g/esa/ilc/epics/modules/streamdevice-2-3")
epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
epicsEnvSet( "STREAM_PROTOCOL_PATH","../../atestApp/Db:.")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest
dbLoadDatabase("dbd/atest.dbd",0,0)
atest_registerRecordDeviceDriver(pdbbase)
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
dbLoadRecords("db/atest.db","P=AG:")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest/iocBoot/iocagwfg
iocInit()
Starting iocInit
## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Oct 2 2007
2007/10/24 18:21:44.742 L0 port not connected
2007/10/24 18:21:45.307 AG:RFreq: asynError in write: L0 port is not connected
2007/10/24 18:21:45.308 AG:RFreq: @init handler failed
2007/10/24 18:21:45.308 AG:RFreq: Record initialization failed
2007/10/24 18:21:45.308 AG:WFreq: asynError in write: L0 port is not connected
2007/10/24 18:21:45.308 AG:WFreq: @init handler failed
2007/10/24 18:21:45.308 AG:WFreq: Record initialization failed
Bad init_rec return value PV: AG:WFreq ao: init_record
iocInit: All initialization complete
epics> exit
Here is my atest.db:
record( ai,"$(P)RFreq"){
field( DESC, "read frequency")
field( DTYP, "stream")
field( SCAN, "10 second")
field( PREC, "2")
field( EGU, "Hz")
field( INP, "@atest.proto rFreq L0 8")
record( ao,"$(P)WFreq"){
field( DESC, "write frequency")
field( SCAN, "Passive")
field( PREC, "2")
field( EGU, "Hz")
field( OUT, "@atest.proto wFreq L0 8")
And atest.proto, shown here with both @init statements commented out:
# file: atest.proto
Terminator=LF;
#@init{ out " ";}
rFreq{
out "FREQ?"; in "%f";
wFreq{
out "FREQ %f";
# @init{ rFreq;}
Also here is atestApp/src/Makefile
TOP=../..
include $(TOP)/configure/CONFIG
# ADD MACRO DEFINITIONS AFTER THIS LINE
# build an ioc application
PROD_IOC = atest
DBD += atest.dbd
# atest.dbd will be made up from these files:
atest_DBD += base.dbd
atest_DBD += atestSup.dbd
atest_DBD += stream.dbd
atest_DBD += asyn.dbd
atest_DBD += drvVxi11.dbd
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd
atest_SRCS += atest_registerRecordDeviceDriver.cpp
atest_SRCS_DEFAULT += atestMain.cpp
atest_SRCS_vxWorks += -nil-
#The following adds support from base/src/vxWorks
atest_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
#add a definition for each support application used by this application
atest_LIBS += asyn
atest_LIBS += stream
#atest_LIBS += genSub
#atest_LIBS += calc
atest_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
# ADD RULES AFTER THIS LINE
And contents of my atestSup.dbd:
registrar( drvAsynIPPortRegisterCommands)
When the @init statements are commented out, this is what I get:
< envPaths
iocInit()
Starting iocInit
epics> dbl
AG:RFreq
AG:WFreq
epics>
And I can examine the value read in a very simple edm screen.
Sorry for such a lengthy note. Thanks for helping,
Zen
