Thanks, Bertrand $ sh -x setup.sh + echo '*' * + '[' xdarwin-ppc = x ']' + '[' xdarwin-ppc = x ']' + echo '* Your LD_LIBRARY_PATH must be set and contain' * Your LD_LIBRARY_PATH must be set and contain + echo '* the path to your EPICS base'\''s' * the path to your EPICS base's + echo '* lib/HOST_ARCH resp. lib/EPICS_HOST_ARCH directory' * lib/HOST_ARCH resp. lib/EPICS_HOST_ARCH directory + echo '* so that we can use the CA, Com, ... libraries!' * so that we can use the CA, Com, ... libraries! + echo '* It might also need to include the Motif libraries.' * It might also need to include the Motif libraries. + echo '*' * ++ cd .. ++ pwd + export EDMBASE=/usr/local/epics/extensions/src/edm + EDMBASE=/usr/local/epics/extensions/src/edm + echo Setting up EDM base directory: /usr/local/epics/extensions/src/ edm Setting up EDM base directory: /usr/local/epics/extensions/src/edm + echo '' + '[' xdarwin-ppc = x ']' + ODIR=darwin-ppc + export EDMFILES=/usr/local/epics/extensions/src/edm/setup + EDMFILES=/usr/local/epics/extensions/src/edm/setup + export EDMOBJECTS=/usr/local/epics/extensions/src/edm/setup + EDMOBJECTS=/usr/local/epics/extensions/src/edm/setup + export EDMPVOBJECTS=/usr/local/epics/extensions/src/edm/setup + EDMPVOBJECTS=/usr/local/epics/extensions/src/edm/setup + LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/baselib/ O.darwin-ppc:::/usr/local/epics/base-3.14.8.2/lib/darwin-ppc/ + LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/imagelib/ O.darwin-ppc:/usr/local/epics/extensions/src/edm/baselib/O.darwin- ppc:::/usr/local/epics/base-3.14.8.2/lib/darwin-ppc/ + LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/lib/O.darwin- ppc:/usr/local/epics/extensions/src/edm/imagelib/O.darwin-ppc:/usr/ local/epics/extensions/src/edm/baselib/O.darwin-ppc:::/usr/local/ epics/base-3.14.8.2/lib/darwin-ppc/ + LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/pvlib/O.darwin- ppc:/usr/local/epics/extensions/src/edm/lib/O.darwin-ppc:/usr/local/ epics/extensions/src/edm/imagelib/O.darwin-ppc:/usr/local/epics/ extensions/src/edm/baselib/O.darwin-ppc:::/usr/local/epics/ base-3.14.8.2/lib/darwin-ppc/ + LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/util/O.darwin- ppc:/usr/local/epics/extensions/src/edm/pvlib/O.darwin-ppc:/usr/local/ epics/extensions/src/edm/lib/O.darwin-ppc:/usr/local/epics/extensions/ src/edm/imagelib/O.darwin-ppc:/usr/local/epics/extensions/src/edm/ baselib/O.darwin-ppc:::/usr/local/epics/base-3.14.8.2/lib/darwin-ppc/ + LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/choiceButton/ O.darwin-ppc:/usr/local/epics/extensions/src/edm/util/O.darwin-ppc:/ usr/local/epics/extensions/src/edm/pvlib/O.darwin-ppc:/usr/local/ epics/extensions/src/edm/lib/O.darwin-ppc:/usr/local/epics/extensions/ src/edm/imagelib/O.darwin-ppc:/usr/local/epics/extensions/src/edm/ baselib/O.darwin-ppc:::/usr/local/epics/base-3.14.8.2/lib/darwin-ppc/ + export LD_LIBRARY_PATH + export EDM=/usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/ edm + EDM=/usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm + '[' -f /usr/local/epics/extensions/src/edm/setup/edmPvObjects ']' + /usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm - addpv /usr/local/epics/extensions/src/edm/pvlib/O.darwin-ppc/ libEpics.dylib setup.sh: line 68: 4154 Bus error $EDM -addpv $EDMBASE/ pvlib/O.$ODIR/libEpics.dylib + '[' -f /usr/local/epics/extensions/src/edm/setup/edmObjects ']' + /usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm -add / usr/local/epics/extensions/src/edm/baselib/O.darwin-ppc/libEdmBase.dylib setup.sh: line 80: 4156 Bus error $EDM -add $EDMBASE/ baselib/O.$ODIR/libEdmBase.dylib + /usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm -add / usr/local/epics/extensions/src/edm/imagelib/O.darwin-ppc/lib605432d2- f29d-11d2-973b-00104b8742df.dylib setup.sh: line 80: 4158 Bus error $EDM -add $EDMBASE/ imagelib/O.$ODIR/lib605432d2-f29d-11d2-973b-00104b8742df.dylib + /usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm -add / usr/local/epics/extensions/src/edm/choiceButton/O.darwin-ppc/ lib7e1b4e6f-239d-4650-95e6-a040d41ba633.dylib setup.sh: line 80: 4160 Bus error $EDM -add $EDMBASE/ choiceButton/O.$ODIR/lib7e1b4e6f-239d-4650-95e6-a040d41ba633.dylib + /usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm -add / usr/local/epics/extensions/src/edm/pvFactory/O.darwin-ppc/libPV.dylib setup.sh: line 80: 4162 Bus error $EDM -add $EDMBASE/ pvFactory/O.$ODIR/libPV.dylib
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
