1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Installing EDM on OS X 10.4.10
To: "Bertrand H.J. Biritz" <[email protected]>
Cc: [email protected]
Date: Tue, 16 Oct 2007 06:15:59 -0500
A troubleshooting procedure I use when faced with this type of problem is to use gdb to show where the bus fault is occurring.
Also, I notice that I have different versions of a couple of those fink packages:
openmotif3 2.2.3-11
libpng3 1:1.2.18-1
On Oct 16, 2007, at 12:26 AM, Bertrand H.J. Biritz wrote:
Dear Tech-talk,
in the post about getting MEDM to run on Fedora Core 7 I commented that I could not get EDM to run on my Mac or Linux machines.
Since then I have been offered assistance by Eric Norum and Ernest Williams on fixing this problem.
Right now I am trying to get EDM to run on my PowerBook G4 (1.67GHz) Mac running 10.4.10.
Thus far I have tried the following:
downloaded the latest EDM source (edm-1-11-0ze) and followed the instructions outlined in the README.install file:
I had already installed openmotif (2.2.2.-5), libungif (4.1.4-1) and libpng (libpng3 1:1.2.12-4) during a previous attempt using fink - should I use darwinports instead?
I then ran make without any errors.
Set up the environmental variables as mentioned in the file (using Eric's example as a guide):
EDMBASE=/usr/local/epics/extensions/src/edm
EDMFILES=/usr/local/epics/extensions/src/edm/edmMain/
EDMHELPFILES=/usr/local/epics/extensions/src/edm/helpFiles/
EDMOBJECTS=/usr/local/epics/extensions/src/edm/setup/
EDMPVOBJECTS=/usr/local/epics/extensions/src/edm/setup/
I tried running EDM, but still get a bus error message.
Once that didn't work I tried running the setup.sh script (modifying the .so to .dylib as Eric suggested) and got the following error message:
sh setup.sh
* Your LD_LIBRARY_PATH must be set and contain
* the path to your EPICS base's
* lib/HOST_ARCH resp. lib/EPICS_HOST_ARCH directory
* so that we can use the CA, Com, ... libraries!
* It might also need to include the Motif libraries.
Setting up EDM base directory: /usr/local/epics/extensions/src/edm
setup.sh: line 68: 2702 Bus error $EDM -addpv $EDMBASE/pvlib/O.$ODIR/libEpics.dylib
setup.sh: line 80: 2704 Bus error $EDM -add $EDMBASE/ baselib/O.$ODIR/libEdmBase.dylib
setup.sh: line 80: 2706 Bus error $EDM -add $EDMBASE/ imagelib/O.$ODIR/lib605432d2-f29d-11d2-973b-00104b8742df.dylib
setup.sh: line 80: 2708 Bus error $EDM -add $EDMBASE/ choiceButton/O.$ODIR/lib7e1b4e6f-239d-4650-95e6-a040d41ba633.dylib
setup.sh: line 80: 2710 Bus error $EDM -add $EDMBASE/ pvFactory/O.$ODIR/libPV.dylib
I did include the EPICS libraries
export DYLD_LIBRARY_PATH=$DYLD_LIBRARY_PATH:/usr/local/epics/ base-3.14.8.2/lib/darwin-ppc/
As a final attempt I modified the Makefile in edmMain per Eric's suggestion:
change
   edm_LIBS_Darwin += EdmBase cfcaa62e-8199-11d3-a77f-00104b8742df
to
   edm_LIBS_Darwin += Com EdmBase cfcaa62e-8199-11d3-a77f-00104b8742df
then ran make once more with sadly the same resulting bus error.
Hopefully, there is something simple that I am missing when trying to run EDM.
Thanks for the quick replies to my initial "on the side comment",
Bertrand
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
Installing EDM on OS X 10.4.10 Bertrand H.J. Biritz
Prev: RE: vxWorks network problem on MVME2700 Thompson, David H.
Next: Re: Installing EDM on OS X 10.4.10 Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Installing EDM on OS X 10.4.10 Bertrand H.J. Biritz
Next: Re: Installing EDM on OS X 10.4.10 Bertrand H.J. Biritz
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
