You can get the latest CVS version of medm to compile and run without segfaulting on Fedora 7 with lesstif and lesstif-devel with the following changes:
cvs diff: Diffing .
cvs diff: Diffing medm
Index: medm/medm.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/extensions/src/medm/medm/medm.c,v
retrieving revision 1.165
diff -r1.165 medm.c
457c457
< { "Save All", &xmPushButtonGadgetClass, 'l', "Ctrl<Key>L", NULL, NULL,
> { "Save All", &xmPushButtonGadgetClass, 'l', "Ctrl<Key>L", "Ctrl+L", NULL,
501c501
< { "Overview", &xmPushButtonGadgetClass, 'O', "Ctrl<key>H", NULL, NULL,
> { "Overview", &xmPushButtonGadgetClass, 'O', "Ctrl<key>H", "Ctrl+H", NULL,
cvs diff: Diffing medm/help
cvs diff: Diffing medm/notes
cvs diff: Diffing printUtils
cvs diff: Diffing xc
Index: xc/Matrix.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/extensions/src/medm/xc/Matrix.c,v
diff -r1.16 Matrix.c
43a44
> #ifndef LESSTIF_VERSION
44a46
> #endif
Index: xc/WheelSwitch.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/extensions/src/medm/xc/WheelSwitch.c,v
retrieving revision 1.6
diff -r1.6 WheelSwitch.c
231a232,234
> #ifdef LESSTIF_VERSION
> Widget XmGetTabGroup();
> #else
232a236
> #endif
2687c2691,2696
> if(_XmGetFocusPolicy(widget) == XmEXPLICIT
> && widget != XmGetTabGroup(widget)) {
> (void)XmProcessTraversal(widget, XmTRAVERSE_CURRENT);
> #else
2691a2701
> #endif
2722a2733,2738
> #else
2726a2743
> #endif
2832a2850,2855
> #else
2836a2860
> #endif
I have opened two complex medm screens with this and it displayed them properly. However I have not interacted with the widgets so I don't know if they behave properly under lesstif.
--Bob
----- Original Message -----
Date: Monday, October 15, 2007 2:06 pm
Subject: Re: fedora core 7 medm (was >> Re: MEDM compile - update :)
> Bertrand H.J. Biritz asked:
> > Is there any word on if/when MEDM will work with lesstif?
> APS no longer has any developer(s) permanently tasked with
> maintaining MEDM, although we will assign someone to fix any
> serious bugs that arise and to keep it building on the latest OS
> releases. We only use MEDM with Motif or OpenMotif, and our
> management won't allow us to put any effort into making it work
> with Lesstif. If someone wants to work out what needs changing
> we'd be happy to review and possibly merge any patch files,
> although personally I suspect the problems are all inside Lesstif,
> not in MEDM (we won't accept patches that cause the Motif build to
> break).
> I'm not sure it's worth doing personally (sorry).
> - Andrew
- Re: fedora core 7 medm (was >> Re: MEDM compile - update :) Bertrand H.J. Biritz
- Re: fedora core 7 medm (was >> Re: MEDM compile - update :) Andrew Johnson
Re: which ca_get failed? Jeffrey O. Hill
Installing EDM on OS X 10.4.10 Bertrand H.J. Biritz
<2007>
Re: fedora core 7 medm (was >> Re: MEDM compile - update :) Noboru Yamamoto
genSub Szalata, Zenon M.
<2007>
