1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST
To: Dirk Zimoch <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Fri, 12 Oct 2007 09:34:07 -0700
The first thing I would try is to set EPICS_CAS_BEACON_ADDR_LIST...
There was just a thread about this last week ;-)
http://www.aps.anl.gov/epics/tech-talk/2007/msg01150.php
If you use ports in EPICS_CA_ADDR_LIST (client search request), you will
need to set EPICS_CAS_BEACON_ADDR_LIST (server beacon) manually.
I think the problem you are experimenting is that the beacons are sent
to the same port where search requests only are expected.
EPICS_CAS_BEACON_ADDR_LIST default to EPICS_CA_ADDR_LIST if not set.
Check the server configuration (EPICS_CAS_* envvars) in the channel
access reference manual for more info.
Let us know if it worked!
Emmanuel
On Fri, 2007-10-12 at 14:19 +0200, Dirk Zimoch wrote:
> Hi Jeff and others,
> I see strange crashes of the CA gateway which probably originate in the CAS code.
> If I use an explicit port in EPICS_CA_ADDR_LIST like this
> EPICS_CA_ADDR_LIST="gateway:5066"
> and then start a softioc running a record with an INP link to a record behind
> the gateway (running on that port), the gateway starts printing errors and
> refuses to handle any more requests. It has to be restarted.
> The gateway prints:
> CAS: CAS Request: ? on pc3853.psi.ch:38210: cmd=13 cid=0 typ=11 cnt=5064 psz=0
> avail=81818260
> Oct 12 14:01:36 !!! Errlog message received (message is above)
> bad request code=13 in DG
> filename="../../../../src/cas/generic/st/casDGIntfOS.cc" line number=498
> protocol from client was invalid unexpected problem with UDP input from
> "pc3853.psi.ch:38210"
> avail=81818260
> However, a simple caget works without problems, at least before the softioc
> crashes the gateway.
> I tried 3.14.8 and 3.14.9 on the ioc side. The gateway runs with some pre-3.13.9
> CVS snapshot. But I also tried it with the 3.14.9 libraries.
> BTW: I could not recompile the gateway with 3.14.9, because the function
> epicsNTOH16 does not exist any more. I had to trick the 3.14.9 libraries into
> the gateway's library search path.
> Please, don't remove API functions when changing Channel Access!
> Any idea?
> Dirk
Re: softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Dirk Zimoch
Prev: RE: asyn interrupt and record Mark Rivers
Next: RE: ASYN - calling read after interrupt - fix :) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Dirk Zimoch
Next: Re: softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Dirk Zimoch
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
