Mark Rivers wrote:
> Does
the window has any tool to measure the actual
> network throughput of
the 1GHz ? Or do you have any
> H/W tool to measure it
? If so, how many Mega bytes/sec
> of throughput ?
I don't see a tool in their
software to measure the network throughput. I can do a simple
calculation for the full frame size at 30 FPS 8-bit mode:
1360.*1024.*30.*8 = 334
Mbits/second.
This is the real data
throughput to the display, and does not include any protocol overhead.
The Norpix software includes a
replacement Ethernet driver on Windows which looks at all frames before
the Windows network stack gets them. The camera frames go directly to
the camera application, and only other frames are passed to the Windows
network stack. So using the Window network perfomance monitor shows
virtually no traffic at all.
Does the camera come with it's own display ? Or do you use EPICS CA for
display ? If the real data
throughput to the EPICS display is 334 Mbits/sec,
you should see 42 Mega Bytes/sec of high traffic using the Window
network
perfromace monitor. If it shows no traffic at all, then the display
could be
only 1 frame/second (e.g. 11 Mbits/sec) while the data transfer is 334
Mbits/sec.
What's the protocol the camera use for tranferring the data to the host
PC ?
I thought it's the GigE network. If so, you should see at least 334
Mbits/sec
data throughput on the window network performance monitor. Something
does not make sense to me.
Kate
> Can the window run
remote client ?
I don't
think so. But there is a development library to write your own client.
Mark Rivers wrote:
I recently got a GigE camera
from Prosilica. It is 1360x1024 resolution. At 8-bits the StreamPix
software from Norpix is able to acheive frame rates of 30Hz at full
resolution, and 52 Hz when it is 2x2 binned to 680x512. This is under
Windows, using the single GigE port on the PC, with the camera and PC
connected directly to a GigE switch (which also is connected to the
rest of the LAN).
Does the window has any tool to measure the actual
network throughput of the 1GHz ? Or do you have any
H/W tool to measure it ? If so, how many Mega bytes/sec
of throughput ?
Can the window run remote client ?
Kate
Daron Chabot wrote:
Sorry for not being more clear:
I am only interested in the EPICS and EDM applications you've created
for displaying the video, not in any of the RTEMS-related code.
I did not change any EDM applications or EPICS base. The protocol
is CA. The optimization is implemented at
RTEMS device driver
and IIDC1394 library layers. The BSP is RTEMS-MVME5500.
The driver does not have to be linked to EPICS.
It is just another real-time application with the RTEMS-MVME5500
BSP. It triggers the
camera at 30 fps and display at
30Hz
simultaneously for the 1024x768x8bit mode (video mode) even under the
limited 100MHz network bandwidth and indeterministic
network environment.
Yes, in the 100MHz NIC, the actual network throughput is not
30Hzx1024x768x8 bits. But it is greater than 10Hz. Thus, the system
does
not have to run in a private network. I do not believe it
will be slower with a non-EPICS application.
Here at the CLS we're using
linux-based soft IOCs to communicate with Flea and Flea2 cameras.
We're having difficulty in
achieving video frame rates greater than about 10 Hz at 640x480
resolution. I'm interested to know how you are getting such fine
performance (aside from using RTEMS :-) ).
Perhaps I will have the optimization written in a publication, so that
hopefully it can help the Linux or vxWorks users. If so, will you
feedback to this list regarding how much improvement you achieved
in the Linux driver ?
Kate
- RE: firewire video on RTEMS-4.6.x-MVME5500 Mark Rivers
RE: ASYN - calling read after interrupt - fix :) Mark Rivers
Re: ASYN - calling read after interrupt - fix :) Eric Norum
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
