Mark Rivers wrote:
I recently got a GigE camera
from Prosilica. It is 1360x1024 resolution. At 8-bits the StreamPix
software from Norpix is able to acheive frame rates of 30Hz at full
resolution, and 52 Hz when it is 2x2 binned to 680x512. This is under
Windows, using the single GigE port on the PC, with the camera and PC
connected directly to a GigE switch (which also is connected to the
rest of the LAN).
Does the window has any tool to measure the actual
network throughput of the 1GHz ? Or do you have any
H/W tool to measure it ? If so, how many Mega bytes/sec
of throughput ?
Can the window run remote client ?
Kate
Daron Chabot wrote:
Sorry for not being more clear:
I am only interested in the EPICS and EDM applications you've created
for displaying the video, not in any of the RTEMS-related code.
I did not change any EDM applications or EPICS base. The protocol
is CA. The optimization is implemented at
RTEMS device driver
and IIDC1394 library layers. The BSP is RTEMS-MVME5500.
The driver does not have to be linked to EPICS.
It is just another real-time application with the RTEMS-MVME5500
BSP. It triggers the
camera at 30 fps and display at
30Hz
simultaneously for the 1024x768x8bit mode (video mode) even under the
limited 100MHz network bandwidth and indeterministic
network environment.
Yes, in the 100MHz NIC, the actual network throughput is not
30Hzx1024x768x8 bits. But it is greater than 10Hz. Thus, the system
does
not have to run in a private network. I do not believe it
will be slower with a non-EPICS application.
Here at the CLS we're using
linux-based soft IOCs to communicate with Flea and Flea2 cameras.
We're having difficulty in
achieving video frame rates greater than about 10 Hz at 640x480
resolution. I'm interested to know how you are getting such fine
performance (aside from using RTEMS :-) ).
Perhaps I will have the optimization written in a publication, so that
hopefully it can help the Linux or vxWorks users. If so, will you
feedback to this list regarding how much improvement you achieved
in the Linux driver ?
Kate
- RE: firewire video on RTEMS-4.6.x-MVME5500 Mark Rivers
ICALEPCS07 conference Kate Feng
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
