1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CAMAC IO
To: "Szalata, Zenon M." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 10 Oct 2007 07:52:44 -0500
Szalata, Zenon M. wrote:
I am writing a soft IOC based on asyn which will do CAMAC IO via KS3988 GPIB
crate controller.  I have two problems that I am not sure how to solve. 1.
write a counted array of bytes containing numeric values to the crate
controller.  What record type is well suited for that?
Waveform and genSub are the ones I'd look at first.
2. Also, What record type should I use to read an array of bytes from the
crate controller?
Waveform.
Unrelated question is, Is it possible to modify a field value in a record
from within a subroutine?  To be more specific, I have a sub record and from
its process subroutine I want to modify a field in another record.  Can that
be done?
Yes, but it's not a good idea to do it. Better to use the genSub record, because it has output links.
Thanks, Zen
-- Tim Mooney ([email protected]) (630)252-5417 Beamline Controls & Data Acquisition Group Advanced Photon Source, Argonne National Lab.
Re: CAMAC IO Luedeke Andreas
CAMAC IO Szalata, Zenon M.
Prev: RE: CAMAC IO Paul Sichta
Next: Re: CAMAC IO Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
