1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: embedded python :)
To: Heinrich du Toit <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Wed, 12 Sep 2007 09:23:33 +0900
Hi, Hinrichi:
Very interesting.
Actually, I have experimented similar approach called devPy.
You can use Python to interface your device to EPICS.
It does not uses ASYN and just have AI/AO and WF device support
routines. And I found it is still usefull.
I will definitely look at your code.
Noboru
Heinrich du Toit wrote:
> Hi there
> I've started a project that allows me to run an embedded python script
> inside an IOC using an ASYN driver.
> This allows you to setup (standard) records that using ASYN will call
> python functions (inside classes) directly.
> It's a multi-threaded environment.
> You can use any channel access library available for python.
> It's already in working version - but is still alpha - ie. it needs
> work.
> If your interested download svn source:
> svn co
> http://epicstlabs.svn.sourceforge.net/svnroot/epicstlabs/pythonioc
> pythonioc
> (in one line!)
> If you want to help develop - just sent me an email with your
> sourceforge username.
> If your not interested - well delete this email :P
> cherios
> -Heinrich
begin:vcard
fn:Noboru Yamamoto
n:Yamamoto;Noboru
email;internet:[email protected]
tel;work:+81-29-864-1171, ext. 5209
tel;fax:+81-29-879-6130
x-mozilla-html:FALSE
version:2.1
end:vcard
embedded python :) Heinrich du Toit
Prev: RTEMS Epics build Sue Witherspoon
Next: Re: EDM John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: embedded python :) Heinrich du Toit
Next: Re: embedded python :) Heinrich du Toit
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
