I have this stupid old hardware system.
It is actually very simple. It controls a stepper motor.
But you only have stop/go command
and a analog feedback
but the feedback lags a bit.
This requires you to quite accurately issue stop/go to this device to
position the motor :)
Anyways I think I'm rather going to replace hardware than try to make
this hardware work on new software.
I'm after all actually an engineer ... and not just a programmer :D
On Mon, 2007-09-10 at 09:43 -0700, Emmanuel Mayssat wrote:
> Hello,
> I was wondering what would justify moving to RT linux?
> I was actually contemplating doing the move to RT myself, but finally
> decided against it.
> All RT-required feedback/acquisition/etc are implemented in
> hardware/electronics. As a result, my IOCs don't have to react
> Real-Time.
> But could you describe a "real" situation where RT is necessary?
> Maybe if you have an IOC which is connected to a device that generate
> hardware interrupts, etc. but so far I never encountered such a device.
> Thanks,
> E
> On Mon, 2007-09-10 at 05:59 -0500, David Kline wrote:
> > you can use >=2.6.18 linux kernel/w patch from osadl
> > (http://www.osadl.org/). that will give you rt behavior.
> > /david
> > Heinrich du Toit wrote:
> > > Hi
> > > Did somebody else out there use RTLinux for EPICS?
> > > -Heinrich
- RT linux Heinrich du Toit
- Re: RT linux David Kline
- Re: RT linux Emmanuel Mayssat
RE: asyn for synchronous devices Heinrich du Toit
Re: asyn for synchronous devices John Sinclair
<2007>
Re: RT linux John Sinclair
graphical operator interface based on JAVA Aditya Mandal
<2007>
