1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: epics vxworks time off by 1 hour
To: "'Dennis Nicklaus'" <[email protected]>, <[email protected]>
Date: Fri, 7 Sep 2007 18:01:07 -0600
Dennis,
Based on your symptoms, the code in epicsTime.cpp that converts from an
EPICS time stamp to a date for the proper time zone is working.
The problem must be instead with the implementation of epicsTimeGetCurrent
on vxWorks. See bse/src/libCom/osi/os/vxWorks/iocClock.c. In the startup
script for the IOC do you see that code being installed that calls
iocClockRegister()?
Jeff
-----Original Message-----
On Behalf Of Dennis Nicklaus
Sent: Friday, September 07, 2007 3:02 PM
To: [email protected]
Subject: epics vxworks time off by 1 hour
The time that epics records for updates of my PVs in some vxworks nodes
is off by one hour.  This is the time seen by camonitor, the channel
archiver, etc.
If I run the vxworks time() function which gives me seconds since 1970,
the value returned
matches that returned by unix's time()  (/usr/include/time.h) on my unix
nodes.
I run date() on  vxworks, I also get the correct date and time printed out.
This date() is apparently provided by EPICS since
    lkup "date"
finds it in my EPICS object .munch file.
so the system knows the proper date and time.
But somehow EPICS gets it wrong.  At Geoff's suggestion, I use the epics
IOC shell function
  dbtgf "PV"
to print the update  time, along with other info like this
-> dbtgf "CC2_KLY:ildb0:wave9Flat"
status=0 severity=0
units=
precision=4
time=558040636 315109960
And the first part of the time there is supposed to be seconds since Jan
1 1990 (not 1970)
which should be 631152000 less than the time since 1970
(3600*24*(365*20+5leapdays)) = 631152000
Anyway, the time I get from dbtgf   is also exactly one hour earlier
than it should be
(after I convert by adding 631152000 then comparing to unix's seconds
since 1970).
The dbtgf time matches the camonitor time, both being one hour early.
I even tried to force things a bit by adding these lines to the
beginning of my vxworks boot script:
putenv "TIMEZONE=PSTPDT::480:031102:110402"
putenv "EPICS_TS_MIN_WEST=480"
I'm really in the Central time zone, but I thought I would make it think
I was Pacific time, just
to see what happens.
And after that on vxworks,
date() does print out the time as it should be in the Pacific zone (two
hours earlier
than central), but when I do camonitor on my central time zone unix
machine, it still
tells me the PV update time is one hour too early (one hour earlier than
the actual CDT time here now).
I have run with and without the correct TIMEZONE setting, which is
putenv "TIMEZONE=CSTCDT::360:031102:110402"
but it doesn't make any difference, as well it shouldn't since we are in
the middle of CST and not
on the newly-changed-this-year shoulder dates in March or Nov.
I get this behaviour with my epics objects built with 3.14.7 and 3.14.8.2.
(I had been running 3.14.7 but decided to upgrade since I thought maybe
that was causing the problem here).
vxworks version 5.4
camonitor is 3.14.8.2 and the archiver is built against 3.14.8.2 I believe.
What do I have to do to get epics the correct time?
Thanks
Dennis
[email protected]
epics vxworks time off by 1 hour Dennis Nicklaus
Prev: epics vxworks time off by 1 hour Dennis Nicklaus
Next: Re: epics vxworks time off by 1 hour Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
