1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Building asyn
To: "EPICS tech-talk" <[email protected]>
Date: Fri, 31 Aug 2007 16:20:26 -0700
For those who read my messages about having trouble making linux-gpib:
I now have successfully built and configured linux-gpib after upgrading my linux box to RHEL4/2.6.9-55.0.2.EL.  Many thanks for all the help.
Now, I am stuck making asyn with LINUX_GPIB=YES in RELEASE config file.  I get this error:
gmake -C asyn install
gmake[1]: Entering directory `/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/4-3/asyn'
gmake -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
gmake[2]: Entering directory `/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/4-3/asyn/O.linux-x86'
gmake[2]: *** No rule to make target `/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/4-3/lib/linux-x86//libgpib
.a', needed by `libasyn.a'.  Stop.
gmake[2]: Leaving directory `/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/4-3/asyn/O.linux-x86'
gmake[1]: *** [install.linux-x86] Error 2
gmake[1]: Leaving directory `/afs/slac.stanford.edu/g/esa/esalib/app/epics/support/asyn/4-3/asyn'
gmake: *** [asyn.install] Error 2
Linux-gpib created libgpib.so which is in /usr/local/lib, but I don't see libgpib.a.  There is libgpib.la which I assume is not the same as libgpib.a.
Can asyn use libgpib.so?  If so, what needs to be done to let it know where it exists?  On the other hand, if asyn stubbornly insists on libgpib.a, how can I coax linux-gpib to produce one?  Thanks in advance,
Zen
Prev: Current State of Wago support ? Bill Nolan
Next: Building asyn Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Current State of Wago support ? Mark Rivers
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
