1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: sscan record and StreamDevice positioners
To: Stefan Heim <[email protected]>
Cc: EPICS tech talk <[email protected]>
Date: Thu, 30 Aug 2007 22:22:13 -0500
Stefan Heim wrote:
sorry for the following lengthy expose to a problem regarding completion notification.
I have several positioners (multiple axes devices) controlled via several get/set pairs of ai/ao records per axis with a StreamDevice device support (DTYP=streams).
Sometimes, the underlying "hardware" protocol offers only a set method without completion notification for a given axis. The StreamDevice protocol file section then has s.th. like
setX {
       out "AxisAbs 1 %f";
       in "AxisAbs 1 movement_started";
Here the device emits the "AxisAbs 1 movement_started" as mere confirmation of the control order. There is no further reply indicating completion of the positioning operation.
While moving, the position can be monitored in an event based manner, i.e. a .SCAN="I/O Intr" ai record
| record (ai, "$(IOCNAME):stage:$(AXIS)")
|         field (SCAN, "I/O Intr")
|         field (DTYP, "stream")
|         field (INP,  "@protocol_file.proto get$(AXIS) PORT")
based on a protocol
getX {
       @init {
               out "registerVC 2 IOC:stage:X Joe";
               in "Joe Crds %f %*f %*f %*f %*f %*f %*f ";
Here, the device's capability to do registration based position monitoring is gluelessly linked with EPICS' monitor concept. The out command issued during init causes the device to send position update messages ("Joe Crds ...") as if you posted a monitor on one (or several) EPICS process variable(s).
The six floats thrown away in the "in" part of this protocol ("%*f") are typically read by a further set of (six) .SCAN="I/O Intr" ai records, offering completely seperated control information and linear rescaling of the raw values by means of the respective .ASLO and .AOFF fields. With the same .ASLo/.AOFF rescaling applied to the corresponding ao record of a given axis, this rescaling is transparent to the user/client.
In addition, there is a state variable ("ready") available with the same subscription based event notification mechanism,
| record (bi, "$(IOCNAME):stage:ready")
|         field (INP,  "@protocol_file.proto getReady PORT")
|         field (ZNAM,  "not ready")
|         field (ONAM,  "ready")
with protocol
getReady {
       @init {
               out "registerVC 32 IOC:stage:ready Joe";
               in "Joe %{not ready|ready}";
Now if I want to use the sscan record to operate on these positioners, it expects them to do be capable of ca_put_callback()-based completion notification. However, e.g. travelling from 0.0 to 10.0 takes ~13 s
| sheim@txm1:~$ camonitor TXM1CL:micos:ready TXM1CL:micos:ZCOARSE &
| [1] 7781
! TXM1CL:micos:ready 2007-08-31 02:09:33.733498 ready
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:11.154559 0 LOLO MAJOR
| sheim@txm1:~$ caput -c TXM1CL:micos:setZCOARSE 10
| Old : TXM1CL:micos:setZCOARSE 0
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:44.735909 0.022526
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:44.757608 0.039484
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:44.779335 0.061448
! TXM1CL:micos:ready 2007-08-31 02:09:44.800247 not ready
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:44.803464 0.087914
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:44.828070 0.120282
| New : TXM1CL:micos:setZCOARSE 10
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:44.849671 0.164518
| sheim@txm1:~$
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:44.870746 0.205295 ! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:44.891945 0.251714
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:44.914267 0.303483
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:44.935013 0.36009
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:45.658592 4.99687
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:45.680585 5.21379
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:45.703397 5.42912
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:46.587214 9.98588
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:46.609446 9.99538
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:46.631317 9.99971
! TXM1CL:micos:ZCOARSE 2007-08-31 02:09:46.653736 10
! TXM1CL:micos:ready 2007-08-31 02:09:47.107716 ready
but the caput -c above returns "immediately". Furtermore, the device is possibly late to give out the "not ready" notification (cf. trace above), but guarantees to fire "ready" only after (all) movements finished.
While I read the slides on completion notification in Scans.ppt and tried to understand the busy record, I still wonder what might be the best approach to the problem. Essentially, I need a way to use StreamDevice based devices not offering a synchronous setPosition command as positioners with the sscan record.
Any clues? -Stefan
The busy record is the simplest mechanism I know of for getting a database
like this to behave correctly when written to by a ca_put_callback() -- which
is what the sscan record does when it needs to be notified that something has
finished. (You could write custom device support that would prevent the record
from declaring itself done (i.e., executing its forward link) until the motion
is complete, but this would put the record into a situation it doesn't have code to handle.)
To implement a busy-record based solution, the record that the sscan record
writes to, to start the device moving, must forward link to a record that
writes '1', using a "PP" link, to a busy record's VAL field.  The record that
detects that the motion is finished must cause the busy record's VAL field to
be set back to '0'.  (Normally, it doesn't matter what link type is used to
reset the busy record, but "CA" is the safest, because it handles the
exceptional case in which the motion completes immediately.)
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
sscan record and StreamDevice positioners Stefan Heim
Prev: sscan record and StreamDevice positioners Stefan Heim
Next: Current State of Wago support ? Bill Nolan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
