Thanks Gasper!
I reproduced the bug here and also verified the fix. I created Mantis entry
298 to track the issue and committed the patch to CVS. The fix will show up
in R3.14.10.
cvs diff -- casStrmClient.cc (in directory
C:hillR3.14.dll_hell_fixepicsbasesrccasgeneric)
Index: casStrmClient.cc
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/src/cas/generic/casStrmClient.cc,v
retrieving revision 1.92.2.14
diff -c -b -r1.92.2.14 casStrmClient.cc
*** casStrmClient.cc 18 Nov 2006 01:01:21 -0000 1.92.2.14
--- casStrmClient.cc 29 Aug 2007 17:17:04 -0000
*** 2161,2167 ****
// install allocated area into the DD
! pDD->putRef ( pData, type, pDestructor );
// convert the data from the protocol buffer
--- 2161,2167 ----
! pDD->putRef ( pData, bestWritePrimType, pDestructor );
Jeff
-----Original Message-----
On Behalf Of Gasper Jansa
Sent: Wednesday, August 29, 2007 8:41 AM
To: Ralph Lange
Cc: Yuichi ITOH; EPICS Tech Talk
Subject: Re: gateway problem
Hi All
I checked also on gateway 2.0.0.0 with EPICS base 3.14.7 and it fails to
do a caput -a to waveform with FTVL set to DOUBLE.
I looks like the problem is in file casStrmClient.cc of generic ca server.
Primitive type is changed to aitEnumFixedString on line 2164 (EPICS 3.14.9)
I changed this line to
and is working.
Best Regards
Gasper
Ralph Lange wrote:
> Hello Yuichi,
> could you be a bit more specific about the nature of the problem you
> are experiencing?
> Regards,
> Ralph
> Yuichi ITOH wrote:
>> Hi
>> I am trying to use gateway, and I have encountered with a problem.
>> The problem appeares when writing array data through gateway using
>> "caput -a" command.
>> (Gateway2.0.2.1 built with Base3.14.9 on Scientific Linux 4.2)
>> Writing a scalar data through gateway, it will successfully completed.
>> Writing array data without gateway, it will successfully completed.
>> Environment variable EPICS_CA_MAX_ARRAY_BYTES is correctly set, of
>> course.
>> Has anyone else encountered with this problem?
>> Thanks,
>> Yuichi ITOH
- gateway problem Yuichi ITOH
- Re: gateway problem Ralph Lange
- Re: gateway problem Gasper Jansa
Re: gateway problem Noboru Yamamoto
RE: Frame grabber and image analysis Emmanuel Mayssat
<2007>
<2007>
