1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Heidenhain Absolute Multiturn Rotary Encoder
To: <[email protected]>
Cc: [email protected], Tony Wilson <[email protected]>
Date: Wed, 29 Aug 2007 08:20:28 -0600
At the CLS we use Heidenhain Endat encoders on most of our insertion
devices.  The difficulty is the last time we looked there was no vendors
with a VME endat card.  We ended up having to use a carrier board that
allows you to install PC-104 cards in a VME crate.  If interested, Tony
Wilson wrote the EPICS interface software.  I can provide you with the
AutoCAD drawings for the front-panel and the wiring we use, all the
electronics is commercial off-the-shelf equipment.
Dynatem DPC104 - Is the PC104 carrier board for VME.
MAZeT MMI200 - Is the Endat encoder card.
Elder
To: [email protected]
Subject: Heidenhain Absolute Multiturn Rotary Encoder
Date: Wed, 29 Aug 2007 06:58:39 -0700
At LCLS, we have a requirement for a Heidenhain model ROC-425 or ECN-425
absolute multi-turn rotary encoder. It comes with two types of 'serial'
interface: SSI, or EnDat22.
Are any EPICS users familiar with this model? I am just learning about
these interfaces. If either of them goes directly to a standard serial
port, then asyn support would seem to be ideal.
Thanks in advance for any advice or examples.
______________________________________________________________
Stephen A. Lewis                        |
Linac Coherent Light Source             | [email protected]
Lawrence Livermore National Laboratory  | Tel: 925.423.4751
7000 East Ave, L-210                    | FAX: 925.423.1488
Livermore, CA 94550                     | http://www.llnl.gov
Prev: Heidenhain Absolute Multiturn Rotary Encoder Steve Lewis
Next: Re: Heidenhain Absolute Multiturn Rotary Encoder Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Heidenhain Absolute Multiturn Rotary Encoder Rarback, Harvey
Next: Making linux-gpib Szalata, Zenon M.
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
