1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: gateway problem
To: Yuichi ITOH <[email protected]>
Date: Wed, 29 Aug 2007 13:14:13 +0200
Hello Yuichi,
could you be a bit more specific about the nature of the problem you are experiencing?
Ralph
Yuichi ITOH wrote:
Hi
I am trying to use gateway, and I have encountered with a problem.
The problem appeares when writing array data through gateway using "caput -a" command.
(Gateway2.0.2.1 built with Base3.14.9 on Scientific Linux 4.2)
Writing a scalar data through gateway, it will successfully completed.
Writing array data without gateway, it will successfully completed.
Environment variable EPICS_CA_MAX_ARRAY_BYTES is correctly set, of course.
Has anyone else encountered with this problem?
Yuichi ITOH
Re: gateway problem Gasper Jansa
Re: gateway problem Noboru Yamamoto
gateway problem Yuichi ITOH
Prev: Channel Archiver make problem Umashankar Panda
Next: about building linux-gpib zhangdemin99
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: gateway problem Yuichi ITOH
Next: Re: gateway problem Gasper Jansa
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
